10 bolt Lockrite not engaging #835925 09/14/07 11:24 AM
blue rig Offline OP
Hi, the lockrite locker in my front differential has always worked no problem but it has decided to freewheel which does not make any odd noises and seems to work like a normal open diff. Does anyone have any experience with that? My axle on the right side has exploded one time since I have owned it and I just replaced it and moved on. I am not sure exactly when it stopped working. Should I try to fix the lockrite or should I just save for a 10 bolt selectable? Thanks, Ryan <img src="/forums/images/graemlins/confused.gif" alt="" />
90 Trooper 2.6 -Daily driver/backyard tractor-
Re: 10 bolt Lockrite not engaging [Re: blue rig] #835926 09/15/07 09:42 PM
mlclark Offline
Isuzu Moderator
Ryan-
Two options, you broke the axle within the front housing.
Or, when you grenated that CV, the shock load took out the pins in the lockright. Not uncommon, as when one side breaks, 100% of the torque going to the front driveshaft is put into the non-broken axle.
The only way to tell is to pull it apart.
Good Luck,
Michael
Re: 10 bolt Lockrite not engaging [Re: mlclark] #835927 09/16/07 08:13 PM
blue rig Offline OP
Thanks for the insight Michael. I guess that is the next step. Ryan
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5935 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-10-21 22:06:21 UTC
