89 22RE Studder / hesitation while slightly accelerating. #835943 09/14/07 06:52 PM
Y
yota89 Offline OP
Guys I'm having problems tracking down a studder or hesitation, while slightly depressing the accelerator. If I accelerate hard it doesnt do it. It does it everytime if I'm coasting for a few seconds and then barely press the pedal it will surge like someone is holding a kill switch down and then it resume accelerating, this take place in just a couple of seconds. It started about 3 weeks ago when I changed the spark plugs, so I thought maybe i didnt get one of the plug wires back on good. So i checked the wires per the FSM all under 35K ohms, still didnt help so I bought factory wires, rotor, cap, still does it. I've checked for vacuum leaks with starter fluid, but didnt find anything. Pulled all the plugs none of them were wet looking all looked good. Fresh air filter, TPS was replaced with OEM toyota about 50,000 miles ago, the whole engine was rebuit about 50,000 miles ago so i checked everything per FSM before re assembling. This one has me stumped. If anyone has any ideas, bring them on.
Thanks
89 yota pickup
22RE 261C cam
Tanny / engine rebuilt after 256K
Head machined to RV street spec(EB's)
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: yota89] #835944 09/15/07 03:07 AM
U
uscpeon Offline
mine did what you described, didn't know what the problem was until I cleaned out my throttle body of black sludge, and found out that my timing was retarded. check your timing. stock is 5* jumpered.
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: uscpeon] #835945 09/15/07 03:22 AM
Y
yota89 Offline OP
timing is good, it was 5 jumpered and about 12 without jumper. I thought maybe I got some bad gass but its been several tanks since then. I'm wondering if maybe the O2 sensor is going out.
Thanks
89 yota pickup
22RE 261C cam
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: yota89] #835946 09/15/07 05:13 PM
Y
yota89 Offline OP
Checked the TPS this morning, checked out perfect, reset checked timing, idle, all were fine. double checked for vacuum leaks, found none. This morning while driving seems I can make it happen for a long time if i keep the pedal just barley depressed, I hooked the tack up and it seems to start around 1200 RPM, this is with the the pedal just barely cracked open maybe about a 1/8" moving the butterfly. I was going to check the O2 sensor, but I only have a Digital Volt Meter and when I tried it just read 5v DC the whole time so maybe I need to find a analog so i can see the on and offs of the signal.
89 yota pickup
22RE 261C cam
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: yota89] #835947 09/15/07 05:16 PM
Frank Torres Offline
Your timing should also advance instantly as soon as the throttle opens.
If not you will bog, studder and hesitatate...
Your TPS controls this operation
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: Frank Torres] #835948 09/15/07 10:27 PM
Y
yota89 Offline OP
Yeah it advanced perfectly and never jumped around. Everything is that would normally be related is fairly new except O2 sensor, Injectors were rebuilt when the engine was rebuilt. The exhaust smells like its not burning all the gas r something, its a weird smell, there is also alot of black suit on the edge of the tail pipe, plus im only getting 18 mpg instead of the 22 was getting.
Thanks
89 yota pickup
22RE 261C cam
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: yota89] #835949 09/16/07 01:37 AM
At this point I would do a compression test on the cylinders.
good luck
1998 GS400 for me
1991 Supra SOLD
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: Frank Torres] #835950 09/16/07 06:11 AM
Y
yota89 Offline OP
I dont think im loosing compression, because it will haul butt if I give it just a little bit more gas. Seems it only does it when im in a situation that only requires the lease amount of pedal movement. What exaclty would a compression test tell me other than leak down? Oh yeah the engine only has about 50k on it.
Thanks
89 yota pickup
22RE 261C cam
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: yota89] #835951 09/16/07 03:05 PM
DRTDEVL Offline
I don't know why, but something keeps telling me that the TPS is out of adjustment.
Not the normal way, though... I am thinking it is actually rotated a hair too far clockwise. You know, where the IDL signal is being sent when the throttle is just barely cracked open. The ECU is sending the right amount of fuel for idle, but it is getting too much air, leaning the mix out for that tiny amount of throttle applied. As soon as he pushes past that hair's breadth application, the TPS kicks in, and the ECU starts adjusting the fuel via the o2 and AFM signals.
The only hole in my theory would be the fuel cutoff... If he gets above 1800 rpm without brake application, the injectors would cut off...
Or would that be the cause of his "It does it every time if I'm coasting for a few seconds and then barely press the pedal it will surge like someone is holding a kill switch down and then it resume accelerating, this take place in just a couple of seconds."?
Re: 89 22RE Studder / hesitation while slightly accelerating. [Re: yota89] #835952 09/16/07 05:42 PM
A compression test would tell the differance in compression between cylinder.
Idle would be rough with when a cylinder or two has low numbers, this may be due to a burnt valve or a headgasket that has been compromised between cylinders.
Also a weak fuel pump will produce a poor spray pattern at the injectors and result in unburnt fuel and poor idle.
But I would re-adjust the TPS, sounds like the timing is advancing a little late.
Good luck
1998 GS400 for me
1991 Supra SOLD
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6412 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-06-07 09:07:14 UTC
