Elocker (grey wire mode/blue wire?) #77827 03/12/03 04:27 AM
Rob_dup2 Offline OP
Ok sorry to bring this subject up again. Please believe me I did do a search but haven't found the exact information I'm looking for. I am looking for the write up/mod which will allow me to lock the rear diff whenever I would like. I have '97 limited.
I did find 'Phong's' write up which he states:
"...To disable the 4LO safety, you have to cut the '4WD' line, which is pin #8 (blue/red) on the ECU, and ground it. The locker will now work in 2HI, 4HI, and 4LO......" 20004runner (Thanks)
Can someone please verify what I may need to do or point me in the right direction to do this for my '97?
Thank you very much.
Rob
Re: Elocker (grey wire mode/blue wire?) #77828 03/12/03 04:31 AM
http://www.hboss.net/4runner/mods.htm
bottom of the page. It's pretty self explanatory... Steve said you could use a T-tap connector instead of cutting the wire for a less permanent modification, but I see no reason why you would ever want to re-enable the safety.
<small>[ March 11, 2003, 10:35 PM: Message edited by: phong ]</small>
Re: Elocker (grey wire mode/blue wire?) #77829 03/12/03 05:40 AM
Rob_dup2 Offline OP
Thanks for more pics regarding this. I just wasn't sure if my '97 will be the same way. I'll have to pull the kick panel off and take a look at it.
Re: Elocker (grey wire mode/blue wire?) #77830 03/13/03 05:54 AM
Nothing extravagant, but here's a detailed write-up for the '97 4Runner:
Link
<small>[ March 13, 2003, 12:06 AM: Message edited by: HBoss ]</small>
Re: Elocker (grey wire mode/blue wire?) #77831 03/13/03 06:36 AM
jx94148 Offline
I think there is another saftey for only engauging the rear locker at speeds below 5 mph. Its pin #10 on the same connection. I guess some people keep that one intact and ungrounded.
<small>[ March 13, 2003, 12:37 AM: Message edited by: jx94148 ]</small>
'87 4Runner. '83 Honda XL250R. No mods on either.
Re: Elocker (grey wire mode/blue wire?) #77832 03/13/03 07:20 AM
HBoss, do you know if your write up applies to a '99? Does anyone know if there are any differences from the '97 concerning the ECU or this mod? Thanks
Re: Elocker (grey wire mode/blue wire?) #77833 03/13/03 03:33 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by RobT2K:
<strong>HBoss, do you know if your write up applies to a '99? Does anyone know if there are any differences from the '97 concerning the ECU or this mod? Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I'm 99% sure they're the same.
Re: Elocker (grey wire mode/blue wire?) #77834 03/14/03 06:16 AM
I'd say Phong is correct. His year 2000 & my year 1997 ECU wires and harness are pretty much identical, so I doubt they changed it only for 1999 models.
Re: Elocker (grey wire mode/blue wire?) #77835 03/13/03 07:31 PM
After this mod do you get any weird indications with the RRlock light or 4wheel drive lights?? So everything looks normal after this mod! Cool <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
PHP: 7.4.33 Page Time: 0.019s Queries: 14 (0.015s) Memory: 0.6120 MB (Peak: 0.6972 MB) Data Comp: Off Server Time: 2026-11-18 22:34:47 UTC
