Can I , or is it even possible to tow a 94 4runner with a taco v6? 1200miles? #835974 09/14/07 11:13 PM
O
Omega Supreme Offline OP
Like it states, i have a 1994 4runner to pick up in socal and drive it all the way up to washington. Can it be done in a 2001 v6 extra cab sr5 4x4? Or will i just toast the engine and clutch? Thanks for the help!! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> I looked up gross vehicle wieght for a 94 4runner and its right around 3700 lbs. But i think i will take the seats out to try to lighten up the load.
Re: Can I , or is it even possible to tow a 94 4runner with a taco v6? 1200miles? [Re: Omega Supreme] #835975 09/15/07 03:32 AM
W
Whizkidder Offline
Your truck is rated to tow 5000lbs, so the weight should be no problem. The extra weight will likely force you to slip the clutch a bit more than usual to get moving from a full stop, but as long as you're careful, you shouldn't have clutch problems.
If you're going to dingy-tow it (all 4 wheels on the ground), you'll need a good tow bar to be safe, and should remove both front and rear driveshafts on the runner before you tow it. You will also need a set of those add-on (magnetic mount) turn signals (or you could hack into the runner's harness to make it's signals work).
If you're using a car trailer or 2-wheel dolly, just make sure you've got the runner tied down securely. Again, I'd recommend additional turn signals on the back with the dolly.
Good luck!
Re: Can I , or is it even possible to tow a 94 4runner with a taco v6? 1200miles? [Re: Whizkidder] #835976 09/15/07 06:00 PM
O
thanks!!! thats what i wanted to hear. I have a two wheel tow dolly and will be using that. Good to know that i can tow that much. Ya i am going to remove the rear drive shaft after i get it onto the dolly, should make it roll a little easier also. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5946 MB (Peak: 0.6485 MB) Data Comp: Off Server Time: 2026-05-29 16:10:37 UTC
