88 wrangler trans #836005 09/15/07 12:52 PM
8
82shortbox Offline OP
Where the heck is the trans drain and fill plugs. Manual says paaenger side top and bottom of trans, are they allen type plugs Thanks Gordie
Re: 88 wrangler trans [Re: 82shortbox] #836006 09/15/07 03:24 PM
BigJim Offline
I've seen all kinds... If yours has the allen hole in it make sure to get the zactly correct size... one too small will ruin the hole for the correct size wrench.
Re: 88 wrangler trans [Re: 82shortbox] #836007 09/16/07 05:58 AM
BobRowe Offline
Are you talking about an automatic transmission or a manual transmission?
Re: 88 wrangler trans [Re: BigJim] #836008 09/16/07 01:04 PM
8
Manual 5 speed trans. Changed the transfer case and topped off the axles before our first really big trip. Can't really locate the plugs, have two manuals but they really don't help.
Re: 88 wrangler trans [Re: 82shortbox] #836009 09/17/07 05:05 AM
BobRowe Offline
You could Google the manufacturer of the transmission -- they might have drawings of the transmission. You could get a catalog from Four Wheel Drive Hardware -- they have exploded drawings of all Jeep transmissions in the back.
Were it me, I'd just crawl under the vehicle with a flashlight and use my hand and find out where the plugs were.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6049 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-06-07 06:54:47 UTC
