Hood release cable #836760 09/18/07 05:35 PM
HawkFanatic Offline OP
My hood release sticks in the open position. I have to dig at the latch with a screw driver to get the cable to release and the hood to latch closed.
Is it tough to remove from the truck and lube, or should I just replace it?
thanks
1994 Yota 4x4 Short cab
5spd 22RE
Mostly Stock, but I'm learnin'!
31x10.50s
Re: Hood release cable [Re: HawkFanatic] #836761 09/18/07 07:48 PM
mobbinyote Offline
Did you check the alignment of the latch real good first. They're not bad to take out and lube, but if you can't get it to work by just lubing it in the truck, I would just replace the latch.
'82 longbed 4x4,22R,weber 32/36,lce cam,downey header,4" lift,31" swampers,4:56 gears
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5864 MB (Peak: 0.6340 MB) Data Comp: Off Server Time: 2026-06-09 21:46:17 UTC
