chevy 350 transplanted with intermittent miss #836844 09/19/07 02:02 AM
scotia Offline OP
So I have an HEI 350 in my FJ40. It has been running like a top for the last two years and now it has developed a miss. I have checked everything! Wires, plugs, cap, rotor, fuel filter(just in case). Its odd though....runs smooth like new then all of a sudden it runs like I am missing a cylinder. It does this all the time now. Runs great at times then poorly at times. More bad then good though. Does anyone have any thoughts on this? I could be there at a light with it running awesome then It will just change moods on me and run the rest of the drive like crap. Can't see it being a vacuum line as the engine hardly has any on it. No emissions crap either as the engine is from the early 70's. Anything anyone has to offer would be great.
Re: chevy 350 transplanted with intermittent miss [Re: scotia] #836845 09/19/07 02:56 AM
G
Greg_Canada Offline
How are your grounds?
89 4Runner
Re: chevy 350 transplanted with intermittent miss [Re: Greg_Canada] #836846 09/19/07 01:07 PM
scotia Offline OP
Should be good as I changed it up. Ran a ground from engine to battery then from battery to frame. Also pulled the valve covers to see if I had a broken valve spring. Nothing yet.
Re: chevy 350 transplanted with intermittent miss [Re: scotia] #836847 09/19/07 05:51 PM
Baldy Offline
Check the HEI module under the cap
Re: chevy 350 transplanted with intermittent miss [Re: Baldy] #836848 09/19/07 08:57 PM
V
v8yota Offline
x 2 on the HEI module what kind of carb are you using,,,is there any black crap in your tailpipes
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6011 MB (Peak: 0.6648 MB) Data Comp: Off Server Time: 2026-06-23 01:11:26 UTC
