thee dana 30? #836878 09/19/07 05:19 AM
thurrsROB Offline OP
I have 90' YJ with the AWESOME! (yeah right) disconnect and i just poured money into my NP231 with an SYE kit. Im thinkin of upgrading the Dana 30 but am not sure. Does anyone know first hand if they are really that strong? Would the 30 spline chromoly shafts be worth the money? Should i just swap the T-case and upgrade the axle?
AND UHH...the product description on the 30 spline axles for the DANA 30 says that they eliminate the disconnect. Hows that?
thanx
Rob
rob
Re: thee dana 30? [Re: thurrsROB] #836879 09/19/07 05:54 AM
BobRowe Offline
Don't forget --- if you change from the 27 spline to the 30 spline shafts, then you'll have to change to 30-spline hubs on the outboard ends, and you'll have to change to 30-spine differential.
Re: thee dana 30? [Re: thurrsROB] #836880 09/19/07 02:31 PM
DBL_DTY97TJ Offline
I'd leave teh 30 alone till it breaks. It's pretty tough stock. It's the 35 rear that's the problem if you still have that stock...
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5921 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-07-14 21:09:34 UTC
