engine kind of howls sounds like a jet when started 1st gen 2.6 #837236 09/21/07 07:40 AM
blackmage Offline OP
so yeah it's been a task of problem after problem with money to finally get my 87 raider running when i start her she makes like a howling jet kind of sound even after warm up don't know if this is normal
sorry for not correct puctucation i'm extremely tired and wondering where i can start looking to figure out my little worry
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: blackmage] #837237 09/21/07 11:02 AM
StockRaider Offline
Waterpump most likely. I had to do the one on my buddys 3.0 Raider.
Have Fun! <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: blackmage] #837238 09/21/07 01:05 PM
toddstidham1 Offline
Use a long screwdriver/pry bar/rod to pinpoint the noise. Place the tip of the screwdriver on a component (say the power steering pump) then carefully lean over and place your ear on the handle. You can use just about anything like a stethiscope just be very careful while the enging is running. Most parts store sell an actual automotive stethiscope for a couple bucks. You'll be amazed the noises you can hear inside the engine (start on the valve cover then work your way down the side to the engine block). In any case, when you find the howling noise, make sure to move the listening point around that general area to pinpoint where it is loudest.
Another thing you can try is to temporarily remove all of the belts then start the engine (do this when it's cold and don't run it too long since the water pump is not spinning). If the howling stopped then you know it's one of the accessories. Put one belt back on and repeat to figure out which accessory is the culprit.
Good luck!
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: blackmage] #837239 09/21/07 05:34 PM
LRJ4x4 Offline
Your factory air cleaner and the tube that connects to the fender is connected?
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: LRJ4x4] #837240 09/21/07 06:55 PM
Run for it! It's trying to morph....
Starter hanging up?
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: fasteddy] #837241 09/21/07 07:33 PM
CapnCrunch Offline
Ditto on what Todd said, but also ditto on the water pump being a likely suspect. When the water pump starts going bad sometimes it'll start whining with a high-pitched noise.
But try the stethoscope routine. That should get you narrowed down to the problem accessory/location. BE VERY CAREFUL where you place it because of the moving fan and belts.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: CapnCrunch] #837242 09/21/07 08:20 PM
LRJ4x4 Offline
Yes and don't wear a tie. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: engine kind of howls sounds like a jet when started 1st gen 2.6 [Re: LRJ4x4] #837243 09/21/07 09:29 PM
StockRaider Offline
the waterpump on the 3.0 howls like a really bad turbo. I joked and said he lost his turbo when I finished the waterpump. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6268 MB (Peak: 0.7213 MB) Data Comp: Off Server Time: 2026-11-19 23:54:13 UTC
