rear end breaks ????
#837321
09/21/07 10:49 PM
<img src="/forums/images/graemlins/scared.gif" alt="" /> well while i was cutting the bedmounts off the frame i cut into the rubber brake hellper or what ever it is called i was wanting to plumb that stright to the brakes to from the frount is it ok to do this or do i need to replace it ? thanx i will be posting my weekend project soon what pics
Re: rear end breaks ????
[Re: 89toyOn35s]
#837322
09/22/07 04:29 PM
Replace the rubber line with another rubber line or a braided stainless line. Fix your speel checker while you're at it! <img src="/forums/images/graemlins/smile.gif" alt="" />
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: toyrunner]
#837323
09/22/07 04:42 PM
It is not a line that I cut it is the thing on the frame that all the lines go to before they go to the drums Might it be all right just to bypass that?
[Re: 89toyOn35s]
#837324
09/22/07 06:03 PM
That would be the proportioning valve (LSPV). You'll need something like that to regulate the rear brake fluid pressure. Either get a used one or you can run a Wilwood prop. valve.
[Re: 4Crawler]
#837325
09/22/07 07:42 PM
Do I need this on the truck it is not an everyday driver?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6121 MB (Peak: 0.6816 MB) Data Comp: Off Server Time: 2026-05-29 20:02:37 UTCValid HTML 5 and Valid CSS
