body bushings #837416 09/22/07 07:05 PM
flyboy367 Offline OP
ok so i frequent a montecarlo website and since i sold my camaro for a monte ss i got into the technical forums. some of those guys are looking for a better body bushing to stiffen the car up. since most f-body guys use aluminum myself included i suggested that. i got some wierd ansewers about that and something to do with the metal of the body and frame. anyway someone said what about delrin. i remeber buying a set of bushings from damn i forget the site but a 2" lift for my sportage. im sure some of you guys have them and im wondering after some offroad abuse how are they still holding up. ill find the site that makes them and if they hold i can get a group buy for monte body bushings.
eventually ill make a post about the monte. it will be stock for a bit till i get my shoulder fixed. after that im going to sculpt it into a nascar replica complete with 358 engine and 4speed manual trans. <img src="/forums/images/graemlins/patriot.gif" alt="" />
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: body bushings [Re: flyboy367] #837417 09/24/07 02:16 AM
Everet Offline
If they are suggesting Delrin, suggest UHMWPE (ultra high molecular weight polyethylene). It is what the body lifts your thinking of are made of. It can withstand as much or more abuse as Delrin and is less expensive.
PM me if you have any questions.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: body bushings [Re: Everet] #837418 09/27/07 11:12 PM
logansportage Offline
That is what the RB body lift is made out of.
Re: body bushings [Re: logansportage] #837419 09/28/07 01:34 AM
Hydra747 Offline
Also, that is what I got! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: body bushings [Re: Everet] #837420 10/02/07 07:00 AM
Hydra747 Offline
Did it! <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6087 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-05-29 22:28:23 UTC
