Page 1 of 3 1 2 3
Diesel Ranger #837424 09/22/07 09:59 PM
samwe Offline OP
I just bought a diesel Ranger and there is not much info on them so I came here.
Do these engines vibrate alot? Mine shakes like crazy at idle. It has worn out the motor mounts.
It is pretty gutless right off idle, but once it is moving seems ok.
I also would like to get some spare glow plugs before winter is fully here. any suggestions on where I can get some?
Re: Diesel Ranger [Re: samwe] #837425 09/22/07 11:01 PM
torquemonster Offline
mine seems to vibrate a little bit at idle, I turned the idle up like 50RPM and its alot smoother now, low idle gets really shaky. I would replace the motor mounts as that can also have it shake.
its probably turbo lag that makes it gutless right off the start, mine has pretty bad lag aswell. I can't tell you where to get glow plugs, I would just try some parts stores if not the mitsubishi dealer can get them, probably a pretty penny though.
Re: Diesel Ranger [Re: samwe] #837426 09/23/07 12:01 AM
hazy_daze Offline
I can give you some P/N's with a tad more info about your truck.
Re: Diesel Ranger [Re: hazy_daze] #837427 09/23/07 02:42 AM
samwe Offline OP
What all do you need to know?
It is an an 86 Ranger 4x4.
Re: Diesel Ranger [Re: torquemonster] #837428 09/23/07 08:22 PM
redbull Offline
Hey TM, where is the idle adjustment on these? Mine idles a little too low as well.
Re: Diesel Ranger [Re: samwe] #837429 09/23/07 08:34 PM
hazy_daze Offline
They're not available in the mainstream parts places, at least not to me. The OE part # is E5TZ12A342A. Should be about $60+/- each from the stealer. HTH <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Diesel Ranger [Re: redbull] #837430 09/23/07 09:43 PM
if you look right on the injection pump there is a little idle screw with a lock nut...very simple to adjust.
Re: Diesel Ranger [Re: torquemonster] #837431 09/24/07 07:39 PM
samwe Offline OP
I am going to buy a 1985 Mitsubishi tomorrow. The Ranger will probably be a parts truck now.
Re: Diesel Ranger [Re: samwe] #837432 01/28/08 09:53 PM
Smeez Offline
I just bought an '86 diesel ranger. Got the best deal of my life on this truck, 94,000 miles, 1 owner, mechanically babied, body is a little banged up but zero rust...get this: $500. Young couple moving to hawaii didn't know what this truck was worth, leaving the states and needed to sell. Anyhow, I am not posting just to brag about my truck, I have run into a small problem and have a couple of questions for y'all.
First, I am really excited to find this forum and have found it helpful already. I would sure love to find service manuals specific to this vehicle, does anyone have them in pdf form?
Okay, bought the truck and picked it up, filled the tank with diesel and drove it home 350 miles, it quite nicely all the way home but seemed to lack a little power especially on hills. I figured fuel, air and oil filter changes would do the trick. I changed the primary and secondary fuel filters and put two gallons of biodiesel in the completely empty tank. I started the truck but and let it warm up for at least five minutes, got in to drive but didn't make it three blocks before it lost power and stalled. It took me about 5 starts just to get it back to my shop. It was extremely cold that night so I figured that the biodiesel had gelled and restricted the fuel flow, figured I'd try it in the morning.
The next morning, I started the truck, it ran fine, drove to the duel station and put 4 gallons of petrol diesel and a touch of anti-gel additive on top of my 2 gal of biodiesel. I got on the freeway to drive the 12 miles home and everything was great at first but then started lacking power and I slowing down, couldn't get up past 45 in 3rd but made it home.
Next day, 12 miles back out to the shop, fine at first but then completely died several times on the freeway, it was horrible. I got it to the shop and thinking that it might still be fuel related, put an additional 6 gallons of petrol in the tank. The truck would start and idle rough, then die. I filled a two liter bottle with diesel and connected a hose from the bottle to the fuel filter in. I also held a bottle underneath the line coming from the fuel tank to the filter in to catch any fuel pumped by the lift pump.
The truck ran fine and idled smooth when running it from the fuel bottle. This is what I noticed in so doing. In the amount of time it took to drain the fuel bottle, the lift pump only pumped a small fraction of fuel compared to what the injection pump took out of the bottle. When I hooked the regular fuel line back up the truck again ran rough and then died.
Here are my questions: is this truck equiped with an injection pump, fuel pump and lift pump and is this problem due to a failing fuel pump or lift pump? Is it possible that there is air in the fuel lines and if so how can I bleed the lines? Could this be a fuel related problem? Also, the injection pump seems to have a slight leak but this has occurred from the beginning, could this be causing the problem. What else should I look at when diagnosing this problem and what would be a good thing to try next?
1986 Ford Ranger 2.3l 4d55t Turbo Diesel 4X4 w/ 5spd
Re: Diesel Ranger [Re: Smeez] #837433 01/30/08 05:01 AM
david85 Offline
The diesel ford ranger had an electric fuel pump in the frame rail forward of the midship fuel tank. When you turn on th ignition, you should hear the buzzing sound of the pump.
If you look at the fuel filter (located at the rear driver's side of the engine) you should see a bleeder valve at the top of the filter. If you open this valve by unscrewing it while the ignition is on, you should get fuel coming out of the filter housing.
If I read your post correctly, the engine will idle without any problems indefinitely?
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6386 MB (Peak: 0.7649 MB) Data Comp: Off Server Time: 2026-11-03 06:07:17 UTC
