where can i find a pinion bearing removal tool #837487 09/23/07 03:34 AM
subliminaltrips Offline OP
im looking for a tool like zuk's clam shell that he uses to hold his bearing while he presses off the pinion. i know he had a machine shop make his but im looking for one that i could possibly buy that is made specificly for the toyota pinion bearing , i have a regular bearing/gear puller but it will destroy the bearing every time.im tempted to try to use a die grinder to modify the gear puller i have now.
Re: where can i find a pinion bearing removal tool [Re: subliminaltrips] #837488 09/23/07 05:27 AM
ZUK Offline
http://www.sjdiscounttools.com/otc1124.html
I bought this exact model....OTC-1124...the pic does not do it justice.....it's a monster size bearing separator that seems to get the pinion bearings off for me. I think it will work for you. It has to be an extra large one like this one that had a good knife edge to get at the bearing.
ZUK
mostly stock
Re: where can i find a pinion bearing removal tool [Re: subliminaltrips] #837489 09/23/07 05:28 AM
ZUK Offline
mostly stock
Re: where can i find a pinion bearing removal tool [Re: ZUK] #837490 09/23/07 04:37 PM
zuk,
thanks, im going to run over to harbor freight and see if they have one that size. if not ill just coin up and get that one.
Re: where can i find a pinion bearing removal tool [Re: subliminaltrips] #837491 09/23/07 08:51 PM
ZUK Offline
The one at Harbor freight will not capture the bearing as well as this one.....this one has much better quality also. The harbor freight one looks tiny compared to the monster one I posted.
mostly stock
Re: where can i find a pinion bearing removal tool [Re: ZUK] #837492 09/23/07 09:35 PM
yea i went over and they had one that was big but it would need to be modified quite a bit. im just going to coin up and get that one. im trying to get my workshop set up to be similar to yours and im going to try to set up 3rds down here in florida. it seems like there arent many shops down here that know how to set them up properly.i use your site as a bible! thanks again zuk
Re: where can i find a pinion bearing removal tool [Re: subliminaltrips] #837493 09/24/07 04:10 AM
theres a guy that says he used this one
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3979
the one i looked at was alot smaller than this one. i may pick this one up and try it. its only a tad bit smaller than the one you posted and a hell of alot cheaper has anyone used this one?
Re: where can i find a pinion bearing removal tool [Re: subliminaltrips] #837494 09/24/07 05:37 PM
Red_Chili Offline
Toyota Section Staffer
I have successfully used the HF splitter on diffs and transmissions. IIRC I modified it a tad, but for $19 I can live with that.
-Bill
Re: where can i find a pinion bearing removal tool [Re: Red_Chili] #837495 09/24/07 06:31 PM
ZUK Offline
This is a V6 pinion bearing.....there's a big difference in the weight and quality of this puller vs the HF one. I never thought I would spend $110 for one of these....but I needed it <img src="/forums/images/graemlins/wink.gif" alt="" />
mostly stock
Re: where can i find a pinion bearing removal tool [Re: ZUK] #837496 09/24/07 11:02 PM
yea i will end up getting one of those but for now the hf will have to do because im broke!!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6366 MB (Peak: 0.7407 MB) Data Comp: Off Server Time: 2026-06-07 07:19:11 UTC
