tools for tierods #837572 09/23/07 06:47 PM
MAC Offline OP
what tools do I need to do my own alignment and replace tie rod ends? (IFS)
Re: tools for tierods [Re: MAC] #837573 09/24/07 02:50 AM
Adam F Offline
97 4R, stock, daily driver
Re: tools for tierods [Re: Adam F] #837574 09/24/07 03:32 AM
4Crawler Offline
Re: tools for tierods [Re: Adam F] #837575 09/24/07 04:10 AM
OOP'S Offline
Possibly a pickle fork if the hammer won't pop the tie rod end free from the steering arm
Most of the time pickle forks will ruin the boot on a TRE. Get their TRE remover works much better. Why do you have to remove the TRE's to do an alignment anyway? Just loosen the clamps and turn the tie rod.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: tools for tierods [Re: OOP'S] #837576 09/24/07 05:27 AM
kewlynx Offline
I take the castle nut off the outer, and give it a whap with the hammer to pop it up/outward; then the inner TRE usually pops right out next.
To the original poster, if replacing the TRE's, count the number of threads on both sides of the link before you tear it down; it'll get you pretty close to where you start with them. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Couple shots of PB Blaster or Aerokroil doesn't hurt either. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: tools for tierods [Re: kewlynx] #837577 09/24/07 05:28 AM
toyotaguy55 Offline
be ready to possibly have to use the torch <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
Re: tools for tierods [Re: OOP'S] #837578 09/24/07 09:44 AM
Adam F Offline
He says he's going to replace the tie rod ends, do it doesn't matter.
Oh...and another tool you'll need to spin off the tie rods is a large adjustable wrench or pliers. LARGE, as big as you can afford. Count the number of turns it takes to remove it, and install the new one the same number to get you close to where you were before.
Re: tools for tierods [Re: Adam F] #837579 09/25/07 11:28 PM
MAC Offline OP
Thanks all. What do I need to turn the sleeves without messing them all up?
Re: tools for tierods [Re: MAC] #837580 09/26/07 01:04 PM
grandeyota Offline
When I replaced mine, I just threaded the tie rods by hand one at a time before I put it the castle nuts on the tie rods. I don't think it matters that the sleeve gets chewed up, mine look like a lion was gnawing on them from when it's been at the alignment shop. Try some vise grips.
Fur clog in the sausage grinder
Re: tools for tierods [Re: MAC] #837581 09/27/07 01:03 AM
1
1986xtracab Offline
they make adjusting claws for the sleeves. http://www.cornwelltools.com/OnlineCatalog/Undercarriage%20and%20Wheel/268alignmentsusp.html
the five piece adjusting set on the right.
1986 xtra-cab 22re
stock everything
1991 bed
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6364 MB (Peak: 0.7421 MB) Data Comp: Off Server Time: 2026-07-13 23:02:27 UTC
