rear diff bearing r&r #837864 09/24/07 07:08 PM
sanuoff Offline OP
well i am attempting to do my own bearings in the rear, i have done bearings for carier and pinions before but i wasnt installing them so i was wondering were there any tricks besides putting it all back the way it came out?
several people say if you put it back with the shims it came with it should be ok, oh and a new crush sleeve.
Re: rear diff bearing r&r [Re: sanuoff] #837865 09/24/07 07:14 PM
4Crawler Offline
See the Tech Section here:
- http://www.4x4wire.com/toyota/tech/gear_setup/
And you could try Zuk's web page:
- http://www.gearinstalls.com/
Re: rear diff bearing r&r [Re: sanuoff] #837866 09/24/07 09:21 PM
ZUK Offline
Mark your spanner ring adjusters...use a new crush with anti-seize compound on the pinion threads and you should have no issues. <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: rear diff bearing r&r [Re: ZUK] #837867 09/24/07 11:43 PM
sanuoff Offline OP
both are great info pages.
thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: rear diff bearing r&r [Re: sanuoff] #837868 09/25/07 01:53 AM
subliminaltrips Offline
id recommend a solid spacer instead of the crush sleeve plus i find then easier to install.
Re: rear diff bearing r&r [Re: subliminaltrips] #837869 09/26/07 02:15 PM
sanuoff Offline OP
well it turned out to be easier than i thought.
pinion bearings is the only ones i changed, i had a friend with experience come and check my work, the only thing i needed was a little more preload on pinion.
.007 is what the back lash was when i put everything back together, which felt like .030 to me on the ring gear but the dial don't lie.
thanks for all the info. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6128 MB (Peak: 0.6822 MB) Data Comp: Off Server Time: 2026-05-29 22:26:37 UTC
