12 bolt tech help
#837877
09/24/07 08:53 PM
I was replacing U- joints in my rear shaft when i found the pinion nut must be loose, I have a ton of play in the pinion,and i can feel bearing slop. So what is a good preload to set the pinion at for torqueing down the yoke Going to be doing this with the third still in.
Re: 12 bolt tech help
[Re: frankinpa]
#837878
09/24/07 09:38 PM
the 12-bolt uses a crush sleeve to set pinion preload. Once "crushed" you simply can't just tighten it more. You need to get a new crush sleeve and start over.
I don't recall what the preload spec is off the top of my head, but keep in mind, with used bearings it will be less than if you were replacing them with new ones.
-Rob
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5855 MB (Peak: 0.6336 MB) Data Comp: Off Server Time: 2026-05-29 18:24:50 UTCValid HTML 5 and Valid CSS
