vibration...t-case bearing??? #838087 09/26/07 12:45 AM
P
PETE_YK Offline OP
Howdy all, i have a vibration thats been getting worse recently and it only occurs when i get on the gas or let off. I understand that this can be caused by a worn bearing/bushing for transfer case output shaft??? Can anyone shed some light? thanks.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: vibration...t-case bearing??? [Re: PETE_YK] #838088 09/26/07 01:58 AM
subliminaltrips Offline
could be a u joint
Re: vibration...t-case bearing??? [Re: PETE_YK] #838089 09/26/07 02:41 AM
4Crawler Offline
Block wheels, tranny in neutral and climb under truck. Grab the rear driveshaft and give it a good tug, top, bottom and middle (by the slip yoke). If you feel any side-side or up-down play, that may be the source of the vibes. If eitehr flange, could be a loose flange nut, remove shaft, unstake nut and torque to spec., restake nut and reinstall shaft.
Re: vibration...t-case bearing??? [Re: 4Crawler] #838090 02/05/08 04:34 PM
dieseltrooper Offline
I've been hearing/feeling something similar. At 60 or more, or when revving past 3K, a buzzy, metallic sound heard from trans/t-case area. Can be felt thru t-case shifter. Output bearing??
Re: vibration...t-case bearing??? [Re: dieseltrooper] #838091 02/05/08 05:31 PM
4Crawler Offline
Again, you can usually feel if anything is loose. Get under the truck and grab hold of the t-case output and give it a tug. Usually should not be able to feel any play if it is tight. And for a 2nd test, pull the rear shaft and do a test drive in FWD and see if the vibes go away or not.
Re: vibration...t-case bearing??? [Re: PETE_YK] #838092 02/05/08 05:41 PM
Jeepeater Offline
When my tcase went south, it started eating speedo drive gears. After the 2nd one was destroyed I dumped the oil because there were metal shavings embedded in the plastic gear (I guess I'm a slow learner because there were shavings in the first failed gear too). What came out of the case was chunky. When the case was pulled apart, it looked like a grenade had gone off in there.
It was the perfect excuse to pick up a rebuilt case from Jim at Inchworm with 4.7 gears in it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Hopefully your tcase problems aren't that extensive.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6130 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-10-24 23:53:04 UTC
