Anyone have.....? #838675 09/28/07 11:37 PM
StreetbikeDepot Offline OP
.....a YJ with SOA and 4"lift springs? I currently have 4" softride and I'm ready to upgrade to an 8.8 in the rear, so I figure its a good time to do the SOA. I know it'll be big, but just wondering if anyone here is set up close to that, pro's cons, and what size tire your running. I'm thinking of only running 35's.
Re: Anyone have.....? [Re: StreetbikeDepot] #838676 09/29/07 07:40 AM
BobRowe Offline
With a SOA and 4" springs, you'd have a total lift of about 9-1/2 inches. I wouldn't want to be in a YJ with that much lift. What size tires you plan to run, and what axles would you be running?
Re: Anyone have.....? [Re: BobRowe] #838677 09/29/07 08:11 AM
8.8 rear and D30 front (might swap the front for a 44 when I SOA, havent decided yet), plan on running 35's or 37's.
Re: Anyone have.....? [Re: StreetbikeDepot] #838678 09/29/07 04:54 PM
Brown81CJ5 Offline
I'd run 39's. With those 4 inch springs and a 1 inch BL, you could run 35's with only a little rubbing.
But, as Bob said that much lift is not very stable. You can easily clear 35's with just the SOA. If you are set on going SOA then I would sell your lift springs for some new OEMs. Or just keep the springs, get a BL, and don't go SOA.
People who get 9+ inches of lift usually drive fullsize trucks with 44+ inch tires for mudding, and have big blocks, or at least V8's.
Oh yeah, you will need to upgrade your front axle shafts if you are going to run 37's on that D30.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6030 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-06-10 07:28:38 UTC
