ball joint tools #838891 09/30/07 12:43 AM
hicojeeper Offline OP
I'm getting ready to replace my ball joint and tie rod ends, I'm finding lots of different shape,size, and priced tools for this job. It seems like the C frame tool would work best but is also the most expensive for a one time (hopefully) job. ????
Re: ball joint tools [Re: hicojeeper] #838892 12/06/07 06:09 PM
RichinROA Offline
Advance and Autozone both have loaner tool programs. Free with deposit. Check them out.
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: ball joint tools [Re: RichinROA] #838893 12/12/07 08:42 PM
Pickle fork, one 8lb sledge with about 12" of the handle cut off, one 4lb drilling hammer, or a fat ball pein. Loosen the castle nut, drive in the pickle fork enough to put the joint under tension, apply 8lb sledge to the eye of the joint as a backstop, and smack it with the 4lb to spring the eye and free the stud. Easiest and cheapest way to go. Even the 8lb hammer is not badly crippled for more common uses, and unless you hit the mark EVERY time, the handle will last longer when it's shorter. I cut the handle on every company sledge...
Re: ball joint tools [Re: fasteddy] #838894 12/13/07 05:43 AM
kewlynx Offline
I just went through that little job on my newer Runner. Air hammer with a pencil nose on it was my buddy. C-clamp is okay, but you'll wail on it. Vise is handy to have.
Made my old Yota herd look like a cake walk.
**ubi apis- ibi salus**
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6004 MB (Peak: 0.6559 MB) Data Comp: Off Server Time: 2026-06-24 14:50:35 UTC
