Page 1 of 3 1 2 3
still haved quetion about dana 30,35 #838920 09/30/07 06:54 AM
P
phil46 Offline OP
how cant chenge difer.whit out having to do tomuch serg.ann whit what other vich.dif a cant use that bolt in in the same please <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> wht out breking the bank
Re: still haved quetion about dana 30,35 [Re: phil46] #838921 09/30/07 07:19 AM
BobRowe Offline
I'm sorry... I just don't understand from your post what you're asking.
Re: still haved quetion about dana 30,35 [Re: phil46] #838922 09/30/07 08:02 AM
Berkeley Offline
Jeep Moderator
Translation: "I have Dana 30 and Dana 35 axles. How can I upgrade them without having to do too much work. Are there any bolt-on axles from any other vehicles which will fit my Jeep without breaking the bank?"
Phil, there's nothing in your post or your profile that tells us what Year/Model Jeep you have. What is it?
Re: still haved quetion about dana 30,35 [Re: Berkeley] #838923 09/30/07 01:36 PM
Oyaji_Jon Offline
From his two other posts on the topic:
i have 93 jeep wranger whit 4.0L afte market,the tran,dife factory.5sp.change to automatic without to have to do to many surgery, change the 35 dana to stronger differential without killing my pocket,without doing so much surgery
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: still haved quetion about dana 30,35 [Re: Oyaji_Jon] #838924 09/30/07 04:43 PM
Brown81CJ5 Offline
Ditch the Dana 35, and swap in a 44 from a wagoneer, or whatever you can find at a junk yard. The 30 up front will be fine, just upgrade the axle shafts, and diff gears.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: still haved quetion about dana 30,35 [Re: Brown81CJ5] #838925 10/01/07 04:39 AM
P
phil46 Offline OP
what year the wagoneer that i need to cut anything <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> im so sorry about my writing before lost my glasses ps.why the squeleton went across the road
Re: still haved quetion about dana 30,35 [Re: phil46] #838926 10/01/07 01:16 PM
superdawg Offline
That AMC 20 is a good axle to swap in, so is a rear Dana 30 from a Scout 800 series? NOT.
Did we ever determine what we are working on? Year/Model/what axles are really in there? Heck he might have a D44 in there now.
This thread is common of the web and forum boards. Someone says"lasd8 asdha aidyet,zzggroon?" and you answer "Well sure a dana 44 from a Wag or what ever else is lying around will work." I like the "or what ever you can find" advice.
By the way a d44 from a wag does not fit under a "jdfg8o9h"
Only a D44 from a 68 commando does.
SD
Re: still haved quetion about dana 30,35 [Re: superdawg] #838927 10/01/07 04:12 PM
Brown81CJ5 Offline
The "whatever you can find" refers to not just a Wagoneer, but anything that has a 44 under it, not "whatever axle he can find".
And you can make any axle fit under any vehicle, but it usually takes some modification.
His last post he said he has a 93 wrangler with a 4.0L.
Gun it and run it!
Re: still haved quetion about dana 30,35 [Re: superdawg] #838928 10/02/07 04:43 AM
P
phil46 Offline OP
im interested on the 44dana, now my skills are pretty good, now i need to know what kind of modifications on that dana 44 that i need to cut the tubing, if it is so, im trying to avoid that. now if this dana can bolt in on the same spot of my dana 35, for a 93 wrangler with 4.0L after market. also i need to know what kind of trani auto for the same jeep. my is 5sp busted. the cost is to rebuild is 1,900 dollars any where in florida, i was thinking to go to the junk and get this items. <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: still haved quetion about dana 30,35 [Re: phil46] #838929 10/02/07 05:21 PM
Brown81CJ5 Offline
As SD said, look for a 68 commando. Or a wrecked rubicon...there you will have some work to do with changing from coils to leafs, and I think shock mount relocation, but you shouldn't have to change the tubes on it.
Gun it and run it!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6386 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-07-17 07:51:06 UTC
