99 Rodeo V6 oil consumption #839086 10/01/07 11:50 AM
rod99rodeo Offline OP
Losing about a quart of oil every 600 miles. No leaks from the oil pan and no white smoke from the exhaust. 110K on the engine. Doesn't seem normal but thought I'd ask for feedback.
Re: 99 Rodeo V6 oil consumption [Re: rod99rodeo] #839087 10/02/07 05:02 AM
Jeff Mason Offline
Do a search. There is a lot of info on here about that. 600 is a little high (my 99 amigo is about the same <img src="/forums/images/graemlins/frown.gif" alt="" /> ) Most seem to get about 1000 per quart...
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: 99 Rodeo V6 oil consumption [Re: rod99rodeo] #839088 10/02/07 07:10 AM
trooperbc Offline
....and no white smoke from the exhaust. 110K on the engine....
....and white smoke would be water or coolant in the combustion chambers
....'blue' is oil
....black is rich
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: 99 Rodeo V6 oil consumption [Re: Jeff Mason] #839089 10/02/07 11:08 AM
Oyaji_Jon Offline
When you search, use +rodeo +oil +consumption newer than 5 years in the Isuzu Forums. I pre-searched it for you and there is some info there. You can try other combinations of search terms to look for more.
HTH
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6019 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-17 11:45:20 UTC
