rear window does not work with tailgate key #839181 10/01/07 07:00 PM
G
Gregg Offline OP
I have a 1987 Toyota 4Runner in which the window does not work using the key in the tailgate. The window works fine with the toggle switch in the center console.
Can someone steer me in the right direction as to what the issue might be? Does the same relay run the window motor from both the toggle switch and tailgate key?
Any help would be appreciated.
Thanks,
Gregg
Re: rear window does not work with tailgate key [Re: Gregg] #839182 10/01/07 07:09 PM
4Crawler Offline
Check the connector behind the glass for the rear switch:
http://www.4crawler.com/4x4/CheapTricks/RearWindow.shtml#Wiper
Re: rear window does not work with tailgate key [Re: 4Crawler] #839183 10/02/07 02:13 AM
G
Gregg Offline OP
I actually already took the panel off and checked out all the rear window connectors etc. The connector to the key switch is firmly in place with no broken wires.
Re: rear window does not work with tailgate key [Re: Gregg] #839184 10/02/07 02:44 AM
4Crawler Offline
Well then, check the relay box for the key switch signals:
- http://www.4crawler.com/4x4/CheapTricks/RearWindow.shtml
Not uncommon for the switch itself to go bad or for the flexing wires to break where the tailgate pivots.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6604 MB) Data Comp: Off Server Time: 2026-06-07 09:41:33 UTC
