clutch in my 22r #839223 10/01/07 11:20 PM
8
82toyota Offline OP
just came back from hill climbing with my truck and the clutch just started slipping all of a sudden climbing a steep hill. so im just wondering with the mods on my truck maybe i need a stronger than stock clutch. ive got 6" rough country lift with 35x14.5's. will a stock clutch do me well on a stock motor??
Re: clutch in my 22r [Re: 82toyota] #839224 10/02/07 03:33 AM
kewlynx Offline
If you still have the stock 4.10 gears pushing those 35" tires, you need to REGEAR. That little mill can't do all that work by itself, so simply getting a heavier clutch isn't the answer, tho' if you are going to stick with that kind of wheeling, it's not a bad idea.
**ubi apis- ibi salus**
Re: clutch in my 22r [Re: kewlynx] #839225 10/02/07 02:40 PM
8
82toyota Offline OP
im pretty new to trucks to tell u the truth. ive been tuning and building honda cars for years and know those things. but trucks i've just gotten into. so you saying i need to regear, do you mean regear the trans or the diffs? i would think in the trans.
Re: clutch in my 22r [Re: 82toyota] #839226 10/03/07 03:21 AM
kewlynx Offline
The diffs. Science in action.
Tech articles on these sites is very helpful.
www.gearinstalls.com Zuk is a member here <img src="/forums/images/graemlins/kewl.gif" alt="" />
www.ringpinion.com Also has a couple calulator tools here.
www.marlincrawler.com
Chock the fronts and get the rear in the air; truck in neutral.
Spin tire, count # of times the driveline turns to 1 revolution of the tire. That should give you an idea of the gearing.
Re: clutch in my 22r [Re: kewlynx] #839227 10/05/07 05:27 PM
8
82toyota Offline OP
yea that makes total sense now. basically if it has not been geared already, i'll have to get new diffs?? with bigger gears or is it possible to put a bigger mill in my existing diffs. seems like there's no diff plate to be removed.
Re: clutch in my 22r [Re: 82toyota] #839228 10/05/07 05:44 PM
DRTDEVL Offline
Look closely at the pics on ZUK's site again.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6127 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-06-07 09:07:32 UTC
