Front Caliper Piston will not budge on my 89
#839377
10/02/07 12:36 PM
Anyone have any idea?
Cannot press the piston back in. Pad is still in. No amount of pressure including c clamp helps. Have also drained part of the fluid from the line.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
Re: Front Caliper Piston will not budge on my 89
[Re: PatrickS]
#839378
10/02/07 01:03 PM
Sounds like it's cock-eyed in the bore.
[Re: hazy_daze]
#839379
10/02/07 01:13 PM
cock-eyed in the bore?
I am getting a little cock-eyed in the head.
How can I check and fix it?
Hate to be such a bore.
[Re: PatrickS]
#839380
10/02/07 01:15 PM
Can you replace the entire caliper? (parts availability question) Once it gets cocked in the bore, the damage is pretty much done.
[Re: hazy_daze]
#839381
10/02/07 01:18 PM
Yes, but first I have to learn how to say cock-eyed in the bore in German.
I was afraid that was the answer.
[Re: PatrickS]
#839382
10/02/07 01:58 PM
der Kolben wird in der langweiligen Angelegenheit gekr³mmt
Clear as mud now? <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: hazy_daze]
#839383
10/02/07 02:19 PM
[Re: hazy_daze]
#839384
10/02/07 02:19 PM
I had a seized caliper a while back, and couldn't get new calipers very quickly, so I rebuilt mine - it was a PITA, but I did get the piston out - I used a BIG c-clamp, and also used the pressure in the system to eventually force the piston out of the caliper - if you go this route, make sure you have new seals/wipers to replace the old ones, and lots of patience.
[Re: PHIL_]
#839385
10/02/07 06:04 PM
Blow it out with pedal pressure. No other method can apply that much force. And it will make a mess....
K-D sells a couple of caliper piston presses. One is just a plate to seat against the caliper with a screw-in pressure screw, and the other anchors the same, but applies pressure like a caulking gun with a squeeze handle and a "ratcheting" pressure rod. I really like the second one. About $40 at NAPA.
[Re: fasteddy]
#839386
10/02/07 07:17 PM
that is why i just spend the money on loaded calipers.then i dont have to worry about any of that.
