1986 toyota 22re reving problems?? #839387 10/02/07 02:51 PM
I
interco40 Offline OP
hey guys i got a 1986 toyota 4runner, i just rebuild the motor and put it in the other day, and got it finailly started last night,but when i rev and hold it there at 1700rpm it will go from 1700 to 1000 none stop like its loosing spark or cutting ou the fuel or somthing. i need help. thanks zack
Re: 1986 toyota 22re reving problems?? [Re: interco40] #839388 10/03/07 04:03 AM
kewlynx Offline
Make sure your TPS is set up properly to start; root of all evil. Make sure your air tube isn't cracked/leaking.
The fuel injector harnesses on the older Toys are butt-spliced; they tend to corrode/fail. This can cause the injectors to misfire. We recommend folks solder them while doing a teardown.
Welcome to the board! <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: 1986 toyota 22re reving problems?? [Re: interco40] #839389 10/03/07 06:21 PM
jdawg13 Offline
also check your idle, mine was too high and the motor was surging.
i lowered it a bit and it purred like a kitten
good luck
Re: 1986 toyota 22re reving problems?? [Re: jdawg13] #839390 10/03/07 11:39 PM
I
yeah i got the tps set so it idles at 800-850, and there is no cranks the intake tube,and the trucks runs better with the fuel return line crimped, but as soon as i crimp the fuel return line it pures like a kittin but it still dose the up and down thing wioth the rpm at 1700 to 1000.
lmk zack
Re: 1986 toyota 22re reving problems?? [Re: interco40] #839391 10/08/07 11:32 PM
I
ok guys i figured it out i was the tps it wasint lined up with throttle pins right.it work awsome today and the it stared to do it again after drining it <img src="/forums/images/graemlins/confused.gif" alt="" /> , so i unpluge the tps and figured the truck would shut of and it ran awsome!but it shorts at points when i drive,like i wants to shut off, i need help her guys im really <img src="/forums/images/graemlins/confused.gif" alt="" />
lmk,zack
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6042 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-10 01:55:07 UTC
