Page 2 of 3 1 2 3
Re: Help with a clutch problem. [Re: 4Crawler] #839500 10/09/07 05:25 PM
toyotaguy55 Offline
^^^^ what he said
toyotas look good with body damage
Re: Help with a clutch problem. [Re: toyotaguy55] #839501 10/09/07 05:55 PM
L
LaCalavera Offline OP
Ok, assuming it's either the slave or master cylinder. Is it a fairly easy thing to do on your own? Or would you recommend taking it somewhere? Cost is a big factor for me considering I am a poor college student. <img src="/forums/images/graemlins/smile.gif" alt="" />
White '91 22RE 4x4 Single Cab
Re: Help with a clutch problem. [Re: LaCalavera] #839502 10/09/07 07:28 PM
4Crawler Offline
Not too hard to change. You need some flare wrenches for the hyd. lines and some way to bleed the lines afterwards. If I remember correctly, mine was the slave cylinder. There was no external leak, it was the piston seal inside the slave letting fluid leak from the high to low pressure side.
Re: Help with a clutch problem. [Re: 4Crawler] #839503 10/09/07 07:32 PM
L
Thanks 4crawler and everyone else who responded. I really appreciate the help you guys have provided. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Help with a clutch problem. [Re: LaCalavera] #839504 10/10/07 12:30 AM
dknight Offline
With it in this position I can throttle the engine and the truck will continue to speed up, eventually something happens and the clutch will disengage indicated by the engine revving as if in idle.
I was going to vote for either bad master or slave or air in the line or leak,
until I read this part. I can't figure out how you could hold the peddle down then suddenly have it work (unless maybe the slave moved a little bit, then the clutch started slipping). Letss hope that replacing the hydraulics fixes it for you.
Re: Help with a clutch problem. [Re: LaCalavera] #839505 10/10/07 12:52 AM
TRDSR5 Offline
Bad Master.
Replace the slave too or a new Master will kill it very soon.
Slaves leak where you can see it.
Masters leak inside the cab and usually under the carpet where you cant.
Air and/or other contaminates is causing the weirdness.
Do it youself, save your book and pizza money...oh and <img src="/forums/images/graemlins/cheers.gif" alt="" />
If I may offer a little driving instruction...Stop shadowing and riding the cluth pedal unless you're a rally driver.
Signed: A Rally Driver <img src="/forums/images/graemlins/smile.gif" alt="" />
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
Re: Help with a clutch problem. [Re: TRDSR5] #839506 10/11/07 01:56 AM
Dieselshop Offline
so what are the chances of this mine is doing the same thing, I just changed the slave and could not bleed it good, I am going to replace the master is i can find one.
Re: Help with a clutch problem. [Re: LaCalavera] #839507 10/11/07 05:31 AM
yota4runna Offline
Definitely an internal master cylinder leak, if you're not losing fluid, with the fluid leaking from one side of the internal cup to the other. Slave cylinders don't have internal leaks. They either work, or they leak onto the ground. New clutch master cylinders aren't expensive.
Re: Help with a clutch problem. [Re: yota4runna] #839508 10/11/07 10:04 AM
Davepet Offline
Sorry to disagree, but the other "side of the internal cup" is just a non pressurized rubber boot that eventually dumps fluid on the inside of the firewall. Leaks show up somewhere, unless they connect to the intake vacuum....
Dave
Re: Help with a clutch problem. [Re: Davepet] #839509 10/11/07 07:12 PM
yota4runna Offline
There are two cups inside the clutch master. When the outer one leaks, you get fluid inside the cab. When the inner one [at the bottom of the piston] leaks, fluid bypasses internally and you get the sinking pedal syndrome or intermittent clutch operation with no external leaks.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6387 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-07-15 15:47:47 UTC
