heater motor #839533 10/03/07 01:51 AM
hicojeeper Offline OP
getting ready to replace my sqealing heater motor in the CJ7, any one know about swapping in a different motor than the stock one for pushing more air?
'80 CJ7; bored 258, weber, MSD, centerforce, rancho 2 1/2 lift, 32" BFG
Re: heater motor [Re: hicojeeper] #839534 10/03/07 03:11 AM
BigJim Offline
For a squeeling fan motor I just drill a small hole into the bearing hump on both ends of the shaft and librally squirt some 30W in the holes. Inside there is a small piece of felt that holds the oil for the bearings.. It has worked everytime for me.. Hold the motor in the upright position before drilling the holes and drill on the topside if possible..
Re: heater motor [Re: hicojeeper] #839535 10/03/07 04:22 AM
O
oldgreen Offline
I believe a motor from an early 80,s full size blazer will work all you need to do is cut a slightly larger hole in the firewall. I,ll check my info its somewhere in the garage and post it up tomorrow.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: heater motor [Re: oldgreen] #839536 10/04/07 08:05 PM
Jeep4Life Offline
Yep a blower from an early 80's blazer is what you want. The parts store will probably ask you what engine you have, no like it makes a difference, I told them I had a 350. You will have to make the hole in the firewall slightly bigger, but not much. Now the low setting blows harder than high used too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5970 MB (Peak: 0.6525 MB) Data Comp: Off Server Time: 2026-06-24 16:15:18 UTC
