22r electric fuel pump/return line? #839580 10/03/07 06:12 AM
P
poolville02 Offline OP
I have a 22r that I'm trying to get running (still <img src="/forums/images/graemlins/rolleyes.gif" alt="" />) and am confused about the fuel pump. Truck came with an inline electric pump on the passenger side frame rail; there is a block off plate on the side of the head where the mechanical pump goes and there is no return fuel line; it was plugged up with a bolt through the hose.
Anyways, the pump went out after a year and I replaced it with the same style electric pump from autozone. The page says it puts out 2.5 to 4.5 psi. Do I need to fab a fuel return line? Does it need a regulator? I was curious if it put more stress on the pump by not having a return. I keep a spare just in case. Also, not sure if its related but, my truck has always ran very rich for some reason.
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
Re: 22r electric fuel pump/return line? [Re: poolville02] #839581 10/03/07 10:44 PM
dcg9381 Offline
The factory pump doesn't need a regulator. It does (in every case I've seen) need a return line. The original hard return line should be on the firewall, passenger side somewhere.
22REturbo.net
1988 4Runner
Re: 22r electric fuel pump/return line? [Re: dcg9381] #839582 10/04/07 12:01 AM
P
The factory return hard line is still there...but It was disconnected by the previous owner.
So what I have are two lines: one feed line from the electric pump to the carb;
and
one line from the tank that is hanging next to the carb, that has been capped off by the previous owner. This is the original return hard line your talking about but where does it connect to?
EDIT: Basically I'm retarded and don't know where the return line hooks up too....hopefully that better explains it lol
Re: 22r electric fuel pump/return line? [Re: poolville02] #839583 10/04/07 12:15 AM
Staceman Offline
Stock carb?
If so, why not just use a stock fuel pump to begin with?
The stock fuel pump has the return on it.
Re: 22r electric fuel pump/return line? [Re: poolville02] #839584 10/04/07 12:48 AM
87Toy4x4 Offline
i run a carter electric fuel pump w/ my 22r and there is no need for a regulator or return line. i just plugged up the factory one.
Re: 22r electric fuel pump/return line? [Re: Staceman] #839585 10/04/07 03:06 AM
P
Stock carb?
Forgot to mention I have the LC adjustable timing gear and don't feel like messing with unless for a last resort.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6108 MB (Peak: 0.6811 MB) Data Comp: Off Server Time: 2026-05-25 19:02:28 UTC
