leaking oil 22re
#839619
10/03/07 06:23 PM
hey all i have an 87 4runna with the 22re in it... friday the motor started leaking out the front of the motor. i thought i tracked the leak to the front oil seal, behind the crankshaft pulley, so i replaced that and did the sleeve on the crankshaft pulley too. The motor leaks even more now. is there something i missed? is there an easy way to track the leak? it is hard to tell where it is coming from exactly because the fan is blowing the oil all over. any suggestions?? thanks Jay
Re: leaking oil 22re
[Re: jdawg13]
#839620
10/03/07 10:11 PM
J Roll Me Over
You need a sleeve on the crank pulley to cover the groove on the sealing surface.
A quick fix (without a sleeve, or when none is available) would be to grind 1/4" off the back of the seal, installing it all the way in. This moves the sealing surface to a new spot on the crank pulley, sealing the leak.
[Re: DRTDEVL]
#839621
10/03/07 11:55 PM
i put the sleeve on the back of the pulley and it leaks worse than ever. how far do i put thes seal in. it is flush with the block, should it be in farther than that??
[Re: jdawg13]
#839622
10/04/07 03:55 AM
i figured out that the glue to attach the sleeve had failed or didn't set up properly and had slipped out of place, causing the leak. I have since replaced the sleeve and seal, no more leak thanks!! jay
[Re: jdawg13]
#839623
10/04/07 04:32 AM
Cool; this is common. Glad you figured it out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6058 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-06-20 17:51:12 UTCValid HTML 5 and Valid CSS
