wheels #839624 10/03/07 06:34 PM
trckdrvr Offline OP
(yes i tried a search)
i was wondering if anybody knew what oem wheels/centercaps would interchange on my '97 T-100 w/ 16'x7' 6 lug wheels? i bought a set of '07 taco wheels/tires(16'x7' 6 lug) and they fit great but the front center cap wouoldn't fit and my old ones wouldn't fit? so i sold them back to the guy,but now i've been reading about wheel spacers. can someone tell me what wheel spacers are and where do they go(behind the wheel or what? thx for any help
Re: wheels [Re: trckdrvr] #839625 10/04/07 04:37 PM
ErikB Offline
Toyota Moderator
There are different types. The thicker type bolt onto the hub, and then the wheel bolts to the spacer. Here are some from Marlin Crawler:
http://www.marlincrawler.com/htm/axles.htm
Another type that Allpro used to carry was a 3/4" spacer that used longer studs, but I don't see them on their web site anymore.
Autoparts places usually care thin 1/4" steel or aluminum spacers as well, but you have to check to see if your studs are long enough, and they may not be thick enough to give you the hub cap clearance you're looking for.
http://home.4x4wire.com/erik
Re: wheels [Re: ErikB] #839626 10/06/07 02:11 AM
trckdrvr Offline OP
thx
Re: wheels [Re: trckdrvr] #839627 10/07/07 06:01 AM
RichieRich Offline
this may sound too easy but, I bought a set of sequia rims the center cap did not fit on the front. after a close look all it took was to trim 1 inch off the bottom of the finger like tabs. they now fit flush as they should and it did not affect the fastening of the cap. here is a pic of it.
Rich
07 Mercedes GL 450
93 Freightliner FL 70 C/C 8.3 cummins, allison auto
96 Toyota T100 4x4 xtra cab v6 5 spd
05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r
04 polaris 500 HO 50th year limited
02 polaris 500 HO
51 willys M38
56 Dj
Re: wheels [Re: RichieRich] #839628 10/07/07 09:37 PM
trckdrvr Offline OP
wow, those wheels look great! do u remember what year sequia? thx
Re: wheels [Re: trckdrvr] #839629 10/12/07 04:57 AM
RichieRich Offline
thanks, they were on craigs list, I gave 400 bucks wheels and tires plus all of the lug nuts. not for sure but maybe like a 02 or something, it should be easy enough to find out. a search for the sequoia may include pics. I'll see if I pull anything up.
edit, I found a site that (for reference only) will show the different years. mine are for 01-04'. they are some on ebay that can give you and idea of cost. good luck
PSS; just rem if you do this you will need a 16" spare also!!!!!!!!
Rich
web page
07 Mercedes GL 450
02 polaris 500 HO
51 willys M38
56 Dj
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6127 MB (Peak: 0.6826 MB) Data Comp: Off Server Time: 2026-10-24 08:19:10 UTC
