"Squeak" in rear shocks after lift #839677 10/04/07 01:24 AM
call_me_Troy Offline OP
Just installed Full Traction 3" economy lift, and the rear shock makes a "cricket" squeak.
Any ideas?
Re: "Squeak" in rear shocks after lift [Re: call_me_Troy] #839678 10/04/07 05:54 AM
BobRowe Offline
1. Did you install new, longer shocks when you installed your 3" suspension lift?
2. Are you sure the noise is coming from the shocks themselves, and not from the bushings at the upper or lower shock mounts?
Re: "Squeak" in rear shocks after lift [Re: BobRowe] #839679 10/04/07 03:14 PM
bhartwell59 Offline
i was about to ask if you had greased the shock eye bushings?
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5916 MB (Peak: 0.6443 MB) Data Comp: Off Server Time: 2026-07-14 21:06:30 UTC
