tie rod collar/sleeve #839770 10/04/07 11:56 AM
F
fugitive4x4 Offline OP
I need a tie rod collar/sleeve that is a bit shorter than the factory spec. My wheel needs aligned inward more, and the collar has no more threads left to adjust the wheel in! Does anyone no where I can get a sleeve for my 97 t100 sr5?
Re: tie rod collar/sleeve [Re: fugitive4x4] #839771 10/04/07 04:19 PM
adam Offline
Napa usually has them in stock, but if it's that far out I's suspect you need new rod ends more than new sleeves.
~Adam
Re: tie rod collar/sleeve [Re: fugitive4x4] #839772 10/04/07 04:41 PM
ErikB Offline
Toyota Moderator
What I've done is cut the sleeve down a bit, as well as the tie rod end(s). You sometimes need to do this if you've got a lift kit.
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5919 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-06-24 13:39:25 UTC
