crank vs. cam direction (timing chain job) #839790 10/04/07 06:32 PM
hunterp Offline OP
hi all,
im about to pop the pulleys off, and get into this thing-following the instructions on roger's page..
the crank is turned to zero, but the notches on the cam gear are at 6 o' clock and not 12.
obviously this is how it ran before for 212K, is everything fine? should i put the new cam gear on with the dimples at 6 again?
thanks.
85 4runner/duals/detroits f&r/5.29s/winch/stuff
Re: crank vs. cam direction (timing chain job) [Re: hunterp] #839791 10/04/07 08:36 PM
1
1986xtracab Offline
if i understand you correctly, spin your crank another 360, it should put your cam at 12 and your crank as well
1986 xtra-cab 22re
stock everything
1991 bed
Re: crank vs. cam direction (timing chain job) [Re: hunterp] #839792 10/04/07 08:37 PM
W
Whizkidder Offline
Bring the crank around one turn -- your cam will end up correct.
Re: crank vs. cam direction (timing chain job) [Re: Whizkidder] #839793 10/04/07 09:24 PM
mosk Offline
nth-ing the previous suggestions.
Background: 4 cycle engine, crank turns twice for each single revolution of the cam (that's why the cam gear has twice as many teeth as the crank gear).
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: crank vs. cam direction (timing chain job) [Re: mosk] #839794 10/05/07 09:04 PM
hunterp Offline OP
ah i see <img src="/forums/images/graemlins/drunk.gif" alt="" />
damn im foggy this morning.
i threw on the new guts (chain, guides, tensioner) with the cam dimples at 6 o clock, i just need to rotate the crank to get them both to face 12 o clock?
s there a true difference between having the cam dimples at 6 rather than 12? or is it just for ease of install?
thanks <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: crank vs. cam direction (timing chain job) [Re: hunterp] #839795 10/06/07 03:14 PM
cktoy Offline
i think its the differance between exhaust stroke and intake stroke,you dont want the valves set for one when they should be doing the other.or some thing along those lines
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6081 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-10-22 01:02:00 UTC
