reoccurin code........
#840381
10/08/07 10:12 AM
have a code that after a few weeks it comes back to haunt me code number: P1123 any help wuld be great.... cheers Ads <img src="/forums/images/graemlins/kewl.gif" alt="" />
THE POWER TO SUPRISE.
Re: reoccurin code........
[Re: Adskia]
#840382
10/08/07 12:26 PM
Kia Moderator Emeritus
Are you sure you got the right numbers?
P1123 is not a valid code, at least according to my FSM which covers 1998-2000 North American Sportages.
Nearest code is P1121 then it jumps to P1307.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Axe Man]
#840383
10/08/07 03:03 PM
This is what the CD that came with my scanner says about code P1123
OBDII P1123 Fuel Trim Additive, System Too Rich
PRIMARY COMPONENT:
Air/Fuel Control System
SECONDARY SENSOR(S):
Mass Air Flow (MAF) Sensor Throttle Position (TP) Sensor Intake Air Temperature (IAT) Sensor Engine Coolant Temperature (ECT) Sensor Oxygen Sensors
FAILURE CONDITIONS
If the air/fuel mixture at idle is too rich for more than 30 seconds during two back-to-back trips, this code will be set and the Malfunction Indicator Light (MIL) will be turned on.
Details:
The code will be triggered if the following conditions are met:
Long term fuel trim value (additive) is less than -0.75 ms (-15% to -20%) for 30 seconds or more Engine speed is less than 880 RPM ) Mass air flow rate is less than 6.1 g/s Engine coolant temperature is greater than 158?F (70?C) Engine in closed loop operation No canister purge occurring
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
[Re: Iron]
#840384
10/08/07 05:34 PM
OBD-II trouble codes beginning with P1XXX are manufacturer specific codes. They CAN have different meanings. I checked around and Kia does not use P1123. See this... http://www.obd-codes.com/trouble_codes/kia/But there IS the possibility that OZ Sportages are different.
[Re: Axe Man]
#840385
10/09/07 09:52 PM
yeh guys that is the number.........and thanks heaps for the explanation of it iron........sounds right to as i went wheelin the other day and it sucked a gut load of mud.........had to clean the airflow meter ......so that explains it .....cleaned it and drove it .....the code appeared again and i cleared it .....and it hsnt come back......thanks heaps guys.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6720 MB) Data Comp: Off Server Time: 2026-06-07 08:29:19 UTCValid HTML 5 and Valid CSS
