Overheating Problem! Please Help!!
#840386
10/08/07 03:11 PM
Hey All, I have a serious overheating problem w/ my Toyota truck. Ive replaced the water pump and the thermostat and it still bubbles up! It runs okay if I leave the thermostat out but then I dont have heat in the truck....and I still have to add water a couple times a week to the radiator..... Please help! <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Overheating Problem! Please Help!!
[Re: highvan]
#840387
10/08/07 04:41 PM
Might be due to a bad head gasket. To test for that condition, pressure test the cooling system, look for a pressure rise with the engine revving. Or do a chemical test on the coolant: - http://www.supras.org.nz/techinfo/bhg.htm
[Re: highvan]
#840388
10/09/07 03:09 AM
Pull and check your spark plugs. See if one or more are "white" - if they are, you're probably leaking coolant into those cylinders. Then do leak down test and watch those cylinders closely- I'm doing my 3.0L fot the second time right now (dealer did it 1st time under warranty about 100,000 miles ago). Good luck.
'90 Toyota Xcab 4x4- sold it '84 RX7 GS '03 Silverado SS
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5914 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-23 04:52:53 UTCValid HTML 5 and Valid CSS
