LUBRICANTS for T100 #840569 10/09/07 02:49 PM
MRT100 Offline OP
LUBRICANTS for T100 SR5 4x4 manual Trans ext cab (125K)
moderate driving 60% city 40 % highway;
occasional off road; very seldom loaded
Please comment on type of lubricants (what you would use) and exchange interval.
5VZ-FE engine
synthetic Mobil 1 - 10W30
Manual Transmission
MT-90 recommended by this group - just replaced, works good so far)
Transfer
GL-5 SAE 85W-90 from Toyota dealer, replaced 5K ago
Differential (looking to replace it)
unknown (probably original)
Chassis
do you follow owners manual or use one kind all purpose grease?
Brakes
DOT3 from Toyota dealer
Clutch line
DOT3 from Toyota dealer (same as for brake lines)
Steering
Power steering fluid by Advance Parts
Thanks
Re: LUBRICANTS for T100 [Re: MRT100] #840570 10/09/07 03:37 PM
garym Offline
Power steering fluid for Toyotas is Dexron ATF or it's generic equivilant.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: LUBRICANTS for T100 [Re: MRT100] #840571 10/09/07 03:40 PM
Perpetrator Offline
Transfer
Chassis
Steering
Thanks
Transfer case should also have a GL-4. It has a synchronizer for the front drive shaft so you can "shift on the fly".
Differentials should have 80W-90 GL-5.
For chassis grease (u-joints, ball joints) I use a NLGI #2 Lithium base grease.
Steering
Power steering should be nothing but Dexron type ATF.
*Edit* garym beat me to the power steering.
1997 T 100 4X4 ExtraCab
5 speed, White
Worthless factory bedliner
265/75/16 Firestone Destination A/Ts
Aisin Manual Hubs
90k miles
Re: LUBRICANTS for T100 [Re: MRT100] #840572 10/09/07 03:57 PM
ErikB Offline
Toyota Moderator
5VZ-FE engine
I've used standard Castrol 5w30 changed at 5k intervals for most of the last 235,000. No problems.
Manual Transmission
MT-90 (same)
Transfer
Redline 75w90 gear oil
Chassis
One size fits all... Yes, you're supposed to use two different types though (moly and non-moly).
Brakes
NAPA DOT4
Clutch line
NAPA DOT4
Steering
Use Dextron type ATF, as it says in the owners manual and right on the cap. Sometimes I use synthetic on my wheeler, but I don't know if I've ever even replaced the PS fluid on my T.
http://home.4x4wire.com/erik
Re: LUBRICANTS for T100 [Re: ErikB] #840573 10/09/07 04:17 PM
adam Offline
5VZ-FE engine
I've also used standard Castrol 5w30 changed at roughly 5k intervals. Tried the high mileage green jug variety for a few changes and found all the leaks in my valve covers. Back on the white jug now with new seals.
Manual Transmission
Mobil 1 75/90 (looking at Royal Purple Synchromesh, more readily available here than Redline)
Transfer
Mobil 1 75/90
Differential
Royal Purple 75w90
Chassis
Mobil1 syn on the ujoints and steering (have greasable endlinks on the SA stuff), "Green" marine grease in the hubs
Brakes
DOT3
Clutch line
DOT3 I guess...never added any or changed it
Steering
Dextron type ATF
~Adam
Re: LUBRICANTS for T100 [Re: adam] #840574 10/09/07 05:13 PM
Honger Offline
5VZ-FE engine
Mobil1 10W-30 for the last 20K miles (I'm at 194K and the Mobil 1 didn't make the valve covers leak any worse)
Automatic Transmission
Whatever it came with when I purchased the truck with 121K. Looking to replace this with a synthetic; probably Mobil 1 or Redline.
Transfer
Generic non-synthetic 75W-90
Rear Differential
Mobil1 75w90
Front Differential
Chassis and Hubs
Mobil1 synthetic (aggravates the snot out of me how the stuff seperates and oozes out of my grease gun)
Brakes
Toyota OEM DOT4
Steering
Dextron type ATF (never changed it)
1998 Toyota T100 SR5 ExtraCab 4WD
Re: LUBRICANTS for T100 [Re: Perpetrator] #840575 10/09/07 05:36 PM
MRT100 Offline OP
TRANSFER-Could you recommend something, please?
I'm little bit confused. Others say Redline 75w90 gear oil
and looks like this is "Exceeds API GL-5"
How often exchanged?
Thanks
Re: LUBRICANTS for T100 [Re: MRT100] #840576 10/09/07 05:56 PM
Perpetrator Offline
Thanks
I put the same thing in my transfer case that I put in the transmission, Redline MT-90.
I don't know how often you should change it.
5 speed, White
Aisin Manual Hubs
90k miles
Re: LUBRICANTS for T100 [Re: Perpetrator] #840577 10/09/07 08:21 PM
ErikB Offline
Toyota Moderator
The MT-90 is probably better for the t-case since it has a synchro for 2wd-4wd. I actually don't remember which I used. Not that big a deal, but shifting from 2wd-4wd on the fly would probably work better w/ the MT-90 because of the additives for the synchros.
I usually change all the fluids every 30k. Including the brake/clutch fluid, since it absorbs moisture that will corrode the piston bores and cause leaks.
Operating fluids [Re: MRT100] #840578 10/10/07 08:58 PM
E
eleet Offline
5VZ... Mobil 1, or Syntec 10W-40, YZZD1 filter
Cooling.. factory red fluid
R150... MT-90
Transfer... MT-90
Front/Rear axles... Redline 75W90NS... cheaper
Hydraulic fluid... ATE Typ200 (DOT4)... just because I have it
Steering... Redline D4... again, just because I have it
Driveshafts. Valvoline Lithium or Lithium + Moly grease depending on specification. I don't know if it matters smile
Wheel bearings... Amsoil GHD
Front axle stubs... inside spindle... Mobilith SHC PM 460
I am looking at some new dealer ball joints right now. For the uppers it looks like they are using a lighter grease like the SHC 460. In the lower there is a heavier black grease.
97 T100 4x4
97 328i
95 540i restoration project
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6443 MB (Peak: 0.7668 MB) Data Comp: Off Server Time: 2026-06-23 03:11:46 UTC
