Page 2 of 3 1 2 3
Re: 22r horsepower recipes [Re: mudboy] #840596 10/10/07 12:50 PM
grandeyota Offline
You've seen these guys right?
LC engineering
Get on the phone with them. They know their stuff and should be able to point you in the right direction. Just keep in mind they are very proud of their parts and will charge ya top dollar if you go that route.
Fur clog in the sausage grinder
Re: 22r horsepower recipes [Re: grandeyota] #840597 10/10/07 03:36 PM
mudboy Offline OP
Thanks alot guys, now we're getting some good suggestions. right now it looks like, 12.5s overbore, polished up crank, of course arps,a double or triple spring,port matched header, adjustable cam gear, tighten up the quench, a heavy flywheel, msd, wideband 02, and a 270 or larger cam.
How about rods? what kind of power do you think I'd be pushing with this? and also do you think it would handle possibly a 50 shot? I'm gonna be ordering my stuff and sending the block/crank out sometime within the month so i just wanna make sure I'm getting the right set up. I'm able to put a motor together but have never really got my recipes down, so all help is highly appreciated. And yes I do know about LC and I have also noticed their proud pricing. I'm not scared to spend it, I'm just budgeting myself so I can still have money to order my longfeilds. I'm hoping she'll go good, with a nice motor, 4.88s, welded back, locked front and cab completly gutted. Also once I start everything, I'll start doing photos as well.
Re: 22r horsepower recipes [Re: mudboy] #840598 10/10/07 05:55 PM
G
Greg_Canada Offline
On the heavy flywheel.. it will only be good for crawling/low speed/low RPM stuff... you're going to want a stock or lighter flywheel for more hp...
remember the lighter the rotating mass the faster it will accelerate.
89 4Runner
Re: 22r horsepower recipes [Re: Greg_Canada] #840599 10/10/07 08:27 PM
mudboy Offline OP
I was thinking that myself and looked on lc's tech articles and read the same that you just posted. A majority of my use is gonna be lining up to the mudhole and once i get in it tear hell through it. the other will be at the mudraces wear i need that top end screamer motor. Its just that I'm a die hard 4 cylinder fan and want to make the most out of it that i can at a reasonable price.
Re: 22r horsepower recipes [Re: mudboy] #840600 10/10/07 10:29 PM
subliminaltrips Offline
i forgot he was talking mud.... a longer duration with alot of lift is good for top end. 1500 at lc engineering wont go far. i think if your die hard 4 cyl toyota look into a supercharger but that would mean a totally different build.
Re: 22r horsepower recipes [Re: subliminaltrips] #840601 10/11/07 01:51 AM
RatLabGuy Offline
If you're boring, why not go w/ a stroker crank too? Get soem real displacement from it.
Question Reality.
Re: 22r horsepower recipes [Re: RatLabGuy] #840602 10/11/07 02:54 AM
G
Greg_Canada Offline
Keep the stroke short and let that puppy rev! longer stroke = slower revving...
89 4Runner
Re: 22r horsepower recipes [Re: Greg_Canada] #840603 10/11/07 06:15 AM
bodo Offline
To get those big tires spinning and keep them that way through the goo is still gonna need some torque.
Since you don't have the HP to keep those big tires going once you hit a deep hole you have to makeup with torque to get them rolling again.
The bogs around here run a 4 and 6 cylinder class and it seems the high HP motors do worse than the stockers because they come off the line with some torque and then bog the tires when they get to the deep nasty part because they don't have any low down omph to get it going again.
I would sacrifice some topend HP and get some more torque with the heavier flywheel unless you are running a bracket racing track.
If you are trying to run 44s in a V8 class and win you are doomed and disregard everything I've said.
Re: 22r horsepower recipes [Re: bodo] #840604 10/11/07 02:23 PM
mudboy Offline OP
I definately understand whats being said with the torque, however even with the stock motor, the 4.88s where enough to get the the tires spinning, so with the top end motor, dont you think th torque would still be at least a little better than stock? i'm asking this cause I really havent seen to many 22r dyno charts to compare the differences
Re: 22r horsepower recipes [Re: mudboy] #840605 10/11/07 04:22 PM
bodo Offline
I looked at some of the pics on the mudinthepines site and the track looks fairly flat so I wouldn't worry about the heavy flywheel.
What class or classes do you plan on running in?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6448 MB (Peak: 0.7671 MB) Data Comp: Off Server Time: 2026-11-03 13:37:25 UTC
