Re: 22r horsepower recipes
[Re: bodo]
#840606
10/11/07 05:38 PM
with 4.88s you would want a torquey engine. 5.29's might be better or a properly setup 5.71 gear.that would keep you up higher with those big tires. taller gears might let you use 4th ,5th gear. find a turbo tranny and you would be better off because of the lower gears.
[Re: subliminaltrips]
#840607
10/11/07 09:18 PM
see I also want to be able to use the truck for local wheeling holes too. The muds not ultra thick at our spots, but grabbing 4th or 5th gear may be a bit much. 5.71s are a little to brittle i think.
#840608
10/11/07 09:32 PM
this may sound stupid but why spend so much to get relatively so little power and no economy just to stay with a 4cyl.Wouldnt a stock 7mgte or similar have more power than the hottest 22r ?
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
[Re: cktoy]
#840609
10/11/07 09:42 PM
well main reason is because i got some of the parts already and also have a good block to work off of. I'm not too familar with the mgte, I do know that i dont see many for sale around here though. Also economy is the least of my concerns.
[Re: mudboy]
#840610
10/11/07 10:26 PM
Realistically, I don't think you're going to get beyond about 145 flywheel hp to that thing without thinking about major work and having to deal with EFI issues. If you can live within the bounds of +20hp - and I mean that power done right with a nice gain over the hp curve, you'll be fine.
If you need more than that, a stroker will take you to 160, a turbo to 200, and then it gets pretty ridiculous to about 300hp. All of these are probably more expensive options over the old fashioned engine swap..
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#840611
10/12/07 02:47 AM
Heres a whole turbo Supra (7MGTE) with a spun bearing. http://southjersey.craigslist.org/car/440269948.htmlDan
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project 87 Turbo Truck, Boost Controller, otherwise stock... for now. 86 Turbo 4Runner, Project
[Re: mudboy]
#840612
10/13/07 04:38 AM
plenty of 5mge mk2 engines still around (also in cressida) start out about 160 hp stock.it just seems like a lot of money in a 22r to get over 150hp trying to make it something it is not meant to be,but more power to you <img src="/forums/images/graemlins/lol.gif" alt="" /> if you can do it.
