1990 Montero body on 1979 Bronco chassis #841006 10/12/07 02:56 AM
fleetbob1 Offline OP
Since building and wheelin my montero for 3 years now, all the abuse has finally caught up with me
the engine is going, the t case and 5 speed needs rebuild.
So instead of spending alot of $ on rebuilding the Montero,
I have a 1979 Ford Bronco frame with a 500HP engine i just finished building,C6 trans,NP205 transfer case, 9" rear with 4.11 and locker,44 high pinion solid axle (front)
After taking careful measurements, the 4 dr body will fit (with alittle afro engeneering)
It will be the "Bronctero"
I will post pix as the build progresses, starting next week !
PS. i am selling the factory rear locker (notlimited slip)
1990 Montero LWB V6 5-SP Locked Rear/33/12.50 Kumho KL-71 Mud Terrains/3" body lift,bars/springs/poly/shocks/custom skids/lots of lights/snorkle/etc......
Re: 1990 Montero body on 1979 Bronco chassis [Re: fleetbob1] #841007 10/12/07 04:21 AM
LRJ4x4 Offline
Wow, I don't think that ever been done a Mitsubfordshi <img src="/forums/images/graemlins/lol.gif" alt="" />
Take Pictures !
Re: 1990 Montero body on 1979 Bronco chassis [Re: fleetbob1] #841008 10/12/07 04:33 AM
Old man engineering is a little more PC. <img src="/forums/images/graemlins/mrt.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
If you leave the wheel base alone, but set the engine andtrans back a little, you'd have good weight distibution. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 1990 Montero body on 1979 Bronco chassis [Re: rxinhed] #841009 10/12/07 05:30 AM
stony-man Offline
That will be cool to see...although the old Broncos are one of only 2 vehicles that I think are cooler looking than the Monty's. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: 1990 Montero body on 1979 Bronco chassis [Re: stony-man] #841010 10/12/07 05:42 AM
LandRaider Offline
500 hp huh? I'd like to see some dyno action. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 1990 Montero body on 1979 Bronco chassis [Re: LandRaider] #841011 10/12/07 07:29 AM
Angelo Offline
Reminds me of whats going on with Franks old Pajero over on the OuterLimits. The work they did to swap a new body over was truly amazing!! Tons of work, but I guess easier than making and swaping over the SAS, or would it?
Good luck,
Angelo
Re: 1990 Montero body on 1979 Bronco chassis [Re: Angelo] #841012 10/12/07 08:31 AM
LandRaider Offline
Anything Bolt on is TONS eaiser than Fabrication. Wrenching to me is mindless work. Changing a water pump, or axle bearings, or pulling a motor requires very little thought, and planning. Some, but not nearly what it takes to SAS a frame, let alone change the front, and rear suspension around.
If I ever find a pristine 2 door truck for cheap, I will be body swapping. Prob have to build a hoist or something, but it will be much much eaiser than re-fabbing everything.
Re: 1990 Montero body on 1979 Bronco chassis [Re: LandRaider] #841013 10/12/07 12:57 PM
stony-man Offline
You can just McVicker-it. <img src="/forums/images/graemlins/smile.gif" alt="" /> Didn't he do his himself, without a hoist? Throw up some pics of that McV. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1990 Montero body on 1979 Bronco chassis [Re: fleetbob1] #841014 10/12/07 09:47 PM
LandRaider Offline
I am selling the factory rear locker (notlimited slip)
Please post some pictures of this 91 factory locker.
Re: 1990 Montero body on 1979 Bronco chassis [Re: LandRaider] #841015 10/12/07 10:24 PM
sparkem Offline
Are you 100% sure it is a locker? Was it welded?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6465 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-06-17 13:45:26 UTC
