Windshield frame differences #841210 10/13/07 03:16 AM
Sc0rp10n Offline OP
Whats the difference between windshield frames for CJ's? I know that the motor mounts at the top or bottom but is there a width difference? I dont feel like shelling out $200 for a new frame, and I can only find frames from years higher than mine.
TIA
Nick <img src="/forums/images/graemlins/patriot.gif" alt="" />
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: Windshield frame differences [Re: Sc0rp10n] #841211 10/13/07 04:15 AM
Brown81CJ5 Offline
I could be wrong, but I believe they are all 55 inches, including the wide tracks.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Windshield frame differences [Re: Sc0rp10n] #841212 10/13/07 05:24 AM
BobRowe Offline
All CJ7's are the same, as well as the later CJ5's. I don't know about the early CJ5's.
Re: Windshield frame differences [Re: Sc0rp10n] #841213 10/16/07 02:47 PM
hlhneast Offline
I am thinking that all 76 and up CJ and YJ windshields are the same with the exception that the YJ has a couple of ribs along the front bottom of the frame for extra strength. The hardware from my 77 CJ fit it fine. When I bought my complete body "kit", as far as I can figure, it was a fiberglass YJ body as a couple of the body mounts were different and the metal W/frame had those ribs I mentioned before. It came with a metal CJ grill. Everything bolted together fine. I did put in a 4 wire W/W motor but the 3 wire mounting holes looked the same. As long as you dont own or buy TJ parts, you should be fine. Before 1976, I have no idea. Hope this helps. <img src="/forums/images/graemlins/notooth.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Re: Windshield frame differences [Re: hlhneast] #841214 10/16/07 05:58 PM
Brown81CJ5 Offline
Found a site that has specs for Jeeps.
jeep specs
Hope this helps.
Gun it and run it!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6028 MB (Peak: 0.6671 MB) Data Comp: Off Server Time: 2026-10-26 03:21:54 UTC
