which cylinder? #841340 10/13/07 05:49 PM
triniphen Offline OP
troubles with the clutch. when the pedal is held down, the clutch slowly engages. i can hear the fork creak as it re-engages. it happens only now and again. no visible leaks so the question is which cylinder it is, top or down below?
Re: which cylinder? [Re: triniphen] #841341 10/15/07 03:06 PM
Mark in AZ Offline
Toyota Moderator
Exploring in a T4R Ltd V8
Re: which cylinder? [Re: triniphen] #841342 10/16/07 02:56 AM
Dandeman Offline
Toyota Moderator
No leaks would indicate upper cylinder... leaking back around the piston internal rubber seal.
Re: which cylinder? [Re: Dandeman] #841343 10/16/07 03:32 AM
azrain Offline
Yup, bypassing.
Luckily, repair parts and rebuild kits are available, cheap and fairly easy to install. Easy two hour (beverage breaks included) project with hand tools.
Re: which cylinder? [Re: azrain] #841344 10/22/07 03:48 AM
got it, i got both rebuild kits for ~$50. i figured i might as well do the slave as well. found a small ping on the master seal and some crud in slave at the end of the cylinder. a couple of hours and badda bing! thx for help/advice <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6043 MB (Peak: 0.6684 MB) Data Comp: Off Server Time: 2026-06-17 10:46:00 UTC
