locked out #841359 10/13/07 07:59 PM
myfrstrodeo Offline OP
my driver side door is locked and i cant pull the lock inside the truck or unlock it with the key outside
Re: locked out [Re: myfrstrodeo] #841360 10/13/07 11:24 PM
Sc0rp10n Offline
....ok....
Model, Year, power or manual locks?
Open up the inside cover of the door, move the mechanism around and hit it with some lube.
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: locked out [Re: Sc0rp10n] #841361 10/15/07 12:00 PM
i fixed it. my 94 rodeo driver door was locked shut. i pulled the driver seat out. then got the door panel off then was able to see a broken spring on the lock mechanism. i was not able to find a spring that fit at my local hardware store so i got the closest one and cut it and bent it to fit. my new spring is stronger than the one that broke
Re: locked out [Re: myfrstrodeo] #841362 10/19/07 02:26 AM
L
Littlewhitepup Offline
Why did you have to remove the seat just to take off the door panel?
Re: locked out [Re: Littlewhitepup] #841363 10/19/07 02:04 PM
jdobbsj Offline
Been there a few years back.. I had to create my own spring as well.. has been fine ever since!!
Here is a link to my old post (which includes a link to an even older post on the topic).
LINK
EDIT by Mod: Please shorten your links.
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
Re: locked out [Re: Littlewhitepup] #841364 10/21/07 02:13 PM
the door was locked shut and there are screws along the bottom of the panel that u cant get at when the door is closed
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6074 MB (Peak: 0.6773 MB) Data Comp: Off Server Time: 2026-06-20 18:12:41 UTC
