locked out
#841359
10/13/07 07:59 PM
my driver side door is locked and i cant pull the lock inside the truck or unlock it with the key outside
Re: locked out
[Re: myfrstrodeo]
#841360
10/13/07 11:24 PM
....ok....
Model, Year, power or manual locks?
Open up the inside cover of the door, move the mechanism around and hit it with some lube.
2000 XJ Classic - Classically a POS 1994 Isuzu Amigo XS -Sold 1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: locked out
[Re: Sc0rp10n]
#841361
10/15/07 12:00 PM
i fixed it. my 94 rodeo driver door was locked shut. i pulled the driver seat out. then got the door panel off then was able to see a broken spring on the lock mechanism. i was not able to find a spring that fit at my local hardware store so i got the closest one and cut it and bent it to fit. my new spring is stronger than the one that broke
Re: locked out
[Re: myfrstrodeo]
#841362
10/19/07 02:26 AM
Why did you have to remove the seat just to take off the door panel?
Re: locked out
[Re: Littlewhitepup]
#841363
10/19/07 02:04 PM
Been there a few years back.. I had to create my own spring as well.. has been fine ever since!! Here is a link to my old post (which includes a link to an even older post on the topic). LINKEDIT by Mod: Please shorten your links.
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
Re: locked out
#841364
10/21/07 02:13 PM
the door was locked shut and there are screws along the bottom of the panel that u cant get at when the door is closed
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6091 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-06-07 04:39:38 UTCValid HTML 5 and Valid CSS
