Plugging brake lines #841512 10/15/07 12:29 AM
trickster Offline OP
I am going to be doing some work on my rigs brakes soon (adding stainless lines). What do you guys use to plug the hard lines so I dont completely drain the master cylinder while I switch flexible lines? I am sure I could come up with something, but maybe someone has a quick simple solution. Thanks.
Wood golf pegs. [Re: trickster] #841513 10/15/07 01:31 AM
Bogo Offline
Wood golf pegs. You know those things they put the balls on when they first hit em down the fairway. I'm not sure plastic would work for a hard line so get wood and don't break them off like my former neighbor did, just stick them in.
-- Bryan
-- Bryan
Re: Wood golf pegs. [Re: Bogo] #841514 10/15/07 01:47 AM
4Crawler Offline
I find the plastic vacuum caps works well (red for the brake lines):
I got a set from JC WHitney but some auto parts stores may have them.
Re: Plugging brake lines [Re: trickster] #841515 10/15/07 01:47 AM
OOP'S Offline
Find some way to push your brake pedal down about an inch or so. This will cover the holes on the reservoir that are in the body of the MC. It will drip a little but will eventually stop. I use my old steering wheel club and put the forked end on the pedal and the other end on the front of the seat cushion.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Plugging brake lines [Re: OOP'S] #841516 10/15/07 04:06 AM
Great ideas, thanks for the suggestions, knew I could count on you guys.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6070 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-10-24 07:18:03 UTC
