85 4x4truck #841620 10/15/07 05:54 AM
I
Iowajohn Offline OP
ok this is the deal, I have an 85 isuzu 4x4 on my fathers place with a diesel in it. Belonged to a x brother-in-law. I remember that the oil line to the turbo cracked and that was the reason it got parked. I am just wondering which engine this is and the source for new turbos, also if this engine is worthy of bringing back to life(hp and torque). I would get the info from the data plate but this thing is buried in multiflora rose and blackberry bushses. I know little of Isuzu trucks, I am sorry to admit, although i do speak Toyota, but willing to learn <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 85 4x4truck [Re: Iowajohn] #841621 10/15/07 10:56 AM
Rxfire Offline
I may be showing my ignorance a little here, but I did not think the turbo pickups came out until 86/87. Of course, a turbo engine could have been retrofitted into the truck. Are you sure it is a turbo? Maybe the oil line to the alternator (combination vacuum pump/alternator) cracked instead of the turbo oil line???
Either way, as long as the oil level did not get too low, neither component going out should not have crippled the engine permanently.
For turbo rebuilds, see:
http://www.majesticturbo.com/index.html
Re: 85 4x4truck [Re: Rxfire] #841622 10/18/07 05:15 AM
I
Iowajohn Offline OP
maybe I was mistaken to I thought I saw the owners manual laying around a a couple of years ago , and i recall it said 85 on it but i must be wrong. Sure it was a turbo because he had the turbo laying on the table. This was years ago.
Re: 85 4x4truck [Re: Iowajohn] #841623 10/22/07 11:33 PM
OutfitBoss Offline
Sounds like you found a very revered vehicle. I would do just about anything to restore an 1985 4x4 Pup with a C223T turbo diesel in it. Still I think the previous poster is right, the Isuzu Pup didn't come from the factory with the turbo, that'd be a C223 normally aspirated engine. Over at http://isuzupup.com they can tell you more about those.
Brian Rodgers
Internet traffic relayed through DIY solar powered WiFi tower.
www.outfitnm.com
1989 Isuzu Pup gasser
2-86 Isuzu Trooper turbo diesels (1 good 1 bad)
Many gallons of biodiesel since 2005
Re: 85 4x4truck [Re: Iowajohn] #841624 10/24/07 12:09 AM
JLEMOND Offline
EASY WAY TO TELL , ALL FACTORY TURBOS CAME WITH A HOOD SCOOP, AND THE AIR CLEANER SET ON TOP OF THE ENG AND WENT UP INTO THE SCOOP , THE SCOOP WAS FOR CLEARENCE NO FUNCTIONAL AIR INLET JERRY
Re: 85 4x4truck [Re: JLEMOND] #841625 11/12/07 06:01 PM
I
Iowajohn Offline OP
well got the truck dug out of the bushes and I see that it is an 86 turbo not and 85 as I thought. Think I will take it apart next spring and see if i can get her running
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6096 MB (Peak: 0.6800 MB) Data Comp: Off Server Time: 2026-06-09 21:54:45 UTC
