Loud Whistling at high RPMs
#841641
10/15/07 05:29 PM
My 86 4runner is making a loud whistling/screaming sound when it is at higher RPMs. What could be causing this?
Re: Loud Whistling at high RPMs
[Re: Jellyfish]
#841642
10/15/07 06:20 PM
[Re: Stinson]
#841643
10/15/07 06:42 PM
Would it be any 1 belt in particular?
[Re: Jellyfish]
#841644
10/15/07 06:57 PM
Check them all, see if any are loose or glazed. To isolate further, you could remove the A/C and/or P/S belts and test drive it. Might also be a failing bearing in an idler pulley on either of those belts. Feel for looseness or gritty feeling in those two pulleys (with the belt off). Bearings can be replaced, I carry some that will fit.
[Re: 4Crawler]
#841645
10/15/07 07:14 PM
Awesome! Thanks for the advice.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6030 MB (Peak: 0.6665 MB) Data Comp: Off Server Time: 2026-06-20 17:39:48 UTCValid HTML 5 and Valid CSS
