Loud Whistling at high RPMs #841641 10/15/07 05:29 PM
Jellyfish Offline OP
My 86 4runner is making a loud whistling/screaming sound when it is at higher RPMs. What could be causing this?
Re: Loud Whistling at high RPMs [Re: Jellyfish] #841642 10/15/07 06:20 PM
Stinson Offline
belt
Re: Loud Whistling at high RPMs [Re: Stinson] #841643 10/15/07 06:42 PM
Would it be any 1 belt in particular?
Re: Loud Whistling at high RPMs [Re: Jellyfish] #841644 10/15/07 06:57 PM
4Crawler Offline
Check them all, see if any are loose or glazed. To isolate further, you could remove the A/C and/or P/S belts and test drive it. Might also be a failing bearing in an idler pulley on either of those belts. Feel for looseness or gritty feeling in those two pulleys (with the belt off). Bearings can be replaced, I carry some that will fit.
Re: Loud Whistling at high RPMs [Re: 4Crawler] #841645 10/15/07 07:14 PM
Awesome! Thanks for the advice.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6034 MB (Peak: 0.6670 MB) Data Comp: Off Server Time: 2026-06-10 06:25:30 UTC
