pulling engine #841736 10/15/07 11:32 PM
MAC Offline OP
Tomorrow AM it finally comes out. Everything loosed ready to go...except for one thing. Can I simply unbolt the p/s pump from the bracket and lay it aside rather than taking the lines apart? Is there enough flex in the lines or OK to stress them a little? don't want to create a problem that does not already exist. Done that before more than once smile
Re: pulling engine [Re: MAC] #841737 10/15/07 11:43 PM
Dieselshop Offline
yea they are long anough just zip tie the pump out of the way
Re: pulling engine [Re: Dieselshop] #841738 10/16/07 01:27 AM
missouriman Offline
there is one bolt that is a pain.
it is behind the pully, but you can get at it with an open end wrench. take all the other bolts out then work on it.. same putting it back on, you have to thread that bolt in a little at a time, but don't tighten it untill you get the others in..
I am assuming 22re...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5909 MB (Peak: 0.6440 MB) Data Comp: Off Server Time: 2026-07-09 17:11:08 UTC
