93' YJ WIper Issues #841749 10/16/07 02:23 AM
3
3355hakukamana Offline OP
I have a 93' YJ the wipers work, the mister works, the sprays work, but the wipers donot return to the park or home position. I have a new switch, disconnected the old one and did a swap before I disassembled the entire column. The new switch functions the same as the old switch, no park position. Anyone got some ideas as to the issue?????
Re: 93' YJ WIper Issues [Re: 3355hakukamana] #841750 10/16/07 01:56 PM
BobRowe Offline
If the wipers won't return to the Park position, the problem lies in the wiper motor assembly, not the wiper switch.
Re: 93' YJ WIper Issues [Re: BobRowe] #841751 10/16/07 02:33 PM
bhartwell59 Offline
just replaced the motor on mine. quieter and wipes faster.
you'll need to tilt the windshield down to get to the motor... on my yj it was a bit of a PITA but the end result was worth it.
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5918 MB (Peak: 0.6444 MB) Data Comp: Off Server Time: 2026-07-14 10:49:56 UTC
