Clutch #841807 10/16/07 06:37 AM
Mudking4717 Offline OP
I have a 89 isuzu trooper 2.6L that needs a new cluch. the repaire shop wants about $700.oo to do it. How hard is it to do it your self. I need to save my self some money or should i have it done.
Thanks, Thomas
Re: cluch [Re: Mudking4717] #841808 10/16/07 06:48 AM
mlclark Offline
Isuzu Moderator
What experience do you have?
What tools do you have?
Have you ever replaced a clutch?
Did you price a clutch kit?
Can you have your vehicle apart a few days to allow for the flywheel to be resurfaced?
Do you have a place that you can do this repair?
How much do you value your time?
Answer those questions and you will know if you can do this yourself. This is not an easy job, but it will require more than a socket set and an apartment parking lot (although, it could be done there).
Michael
Re: cluch [Re: mlclark] #841809 10/16/07 06:56 AM
i have taken the motors out off golf carts quads ect. no one drives it rite now its sitting. We have the tools my dad has rebuilt motors in the past. just to save money if we do it my self.
Re: cluch [Re: Mudking4717] #841810 10/16/07 08:36 AM
mlclark Offline
Isuzu Moderator
Then go for it. It isn't a golf cart, but it is pretty much a pull it and replace it, kind of deal.
I suggest a good repair manual for reference and a bit of searching around here.
Michael
Re: cluch [Re: mlclark] #841811 10/16/07 10:22 PM
94rodeo Offline
I say go for it. Ratchet straps and a good floor jack are your friends. Also remember that to get the upper bolts on the bell houseing, remove the shiftes/boot and put the ratched down through the hole in the cab. Use a bunch of extensions and you should be able to get the top bolts out.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: cluch [Re: 94rodeo] #841812 10/23/07 07:59 PM
ok thanks it will be and after school project, along with c v boots abd brakes
Re: cluch [Re: Mudking4717] #841813 10/25/07 07:50 PM
Storm Trooper Offline
After school for five days at least, right? <img src="/forums/images/graemlins/smile.gif" alt="" />
Be ready for setbacks and long hours, especially if you had to ask if you could do this yourself. A lot of the times, no matter how small the task, there will be complications. Pulling the tranny is both easy and simple at the same time. The concept is easy, unbolt some crossmembers, maybe a slave cylinder, starter, and the tranny istelf and lower it down. Sounds easy, but reality is usually more difficult than the description. Putting it in can be troublesome too, especially getting everything to line back up. Get some friends to help, make sure you pay attention to how you took things out, maybe even label the bolts or something if you are unsure, and be prepared to cuss and bleed a lot. <img src="/forums/images/graemlins/wink.gif" alt="" />
I've pulled my tranny before, swapped my 2.8 for a 3.4, lifted it, and done a few other things, and I know better than to think that any project will go off without a hitch.
I dont mean to rain on your parade. By all means, do yourself a favor and do this work yourself. You will learn so much, and after the sweating, bleeding and cussing is done, you will feel pretty good about your acomplishment.
Good luck, and ask questions here.
'91 Trooper
3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: cluch [Re: Storm Trooper] #841814 10/25/07 08:33 PM
I wasen't going to expect it to be easy. I have a friend who is going to help me. Me him took the tranny out of his dads truck.I have old coffee cans and ziplock bags and going to lable them. I know its going to take time, but I will save my self a lot of money. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: cluch [Re: Mudking4717] #841815 10/26/07 02:13 PM
Sweet!
Perfect then.
I wasn't sure if you knew or not, so thought I'd try to warn you.
Good luck, I'm sure it will go fine. Remember, lots of extensions. They are your friend.
'91 Trooper
Re: cluch [Re: Storm Trooper] #841816 10/27/07 07:20 AM
I used all my extensions and I got all the bolts out. it got dark so I'm pull it out all the way in the morning. Thanks for the tips
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6423 MB (Peak: 0.7640 MB) Data Comp: Off Server Time: 2026-06-17 13:24:24 UTC
